Head unit turns on/off after 20 mins driving
  • Head unit turns on/off after 20 mins driving
    Hi all, I'm experiencing the following issue with my head unit.
    After about 20 mins driving the head unit starts turning itself on/off constantly for five minutes. There is also a clicking noise from the relay below steering wheel which marries up with the head unit turning on/off. After about five minutes all returns to normal. The head unit also stays on sometimes when i remove the keys from the ignition plus when starting car I have to manually turn head unit on.
    No other issues occur with the above. I have 105,000 km on the clock. Methinks the head unit is stuffed? Any one have any advice on this matter? Appreciate any help in advance.
    Sounds like you have a golf 5. Golf 6 or eos....if you do them ignitiin switch faulty. Quite common....VDUB..
    BRISBANE / GOLD COAST
      Yep i think it will be the ignition switch - we bought a Mk6 GTI 2nd hand earlier this year and the head unit was switching itself on and off every few minutes. I did a scan with VCDS and had 5 faults all relating to the ignition switch.
      Bought a new switch from ECS Tuning for $50 odd dollars and replaced it - problem fixed immediately. Mind you, replacing the switch entails removal of the steering wheel, airbag and trim around the steering column. The switch itself is a right bugger to get out without specialist tools.
      Here is a copy of the errors my car had. Check your to see if they are the same/similar.
      Below are the errors:
      Address 16: Steering wheel Labels: 1K0-953-549-MY9.lbl
      Part No SW: 1K0 953 549 CF HW: 1K0 953 549 CF
      Component: J0527 056 0111
      Coding: 0000532
      Shop #: WSC 01357 011 00200
      VCID: 78F5F6390BC86A9
      Subsystem 1 - Part No: 5K0 959 542 Labels: 3C8-959-537.CLB
      Component: E221__MFL-TAS H05 0010
      Coding: 00000130
      Shop #: WSC 00000
      5 Faults Found:
      00576 - Terminal 15
      012 - Electrical Fault in Circuit - Intermittent
      00883 - Ignition Switch (D) Terminal S
      00884 - Ignition Switch (D) Terminal X
      01744 - Ignition Switch Terminal P (D)
      00885 - Ignition Switch (D) Terminal 50
      Ross Tech info:
      00576 - Ross-Tech Wiki
      Part Number Info:
      Vagcom Ross-Tech Codes Ignition Switch Repair - TDIClub Forums
      ECS Tuning Part:
      Ignition Switch
      2015 Audi SQ5 - SOLD
      New car incoming...
        Thanks VDUB & Lukas_R for your detailed response. VDUB I have a MK 6.
        I shall buy a new ignition switch and give it a burl
        Many thanks
