Hi guys, after some advice re AC
So my Octi FL (MK6 based) has AC issues – would seem Mk6 AC is no better than Mk5 which my bank account remembers well.
It has a Clutch-Less Variable Displacement AC Compressor and it is not operating at the low to medium capacity range. From what I understand, the HVAC ecu will ask the compressor to run at high to cool the car, once it is cool the compressor output will decrease to a level that keeps the car constantly cool. Same way an inverter system at home works except home systems are varied by compressor speed, where the car system is varied by changing the piston stroke length.
On a warm day it blows freezing air until the car cools down, then uncooled air (like the compressor has turned off completely) until the cabin temp starts to get uncomfortable, then freezing again ect ect. When it’s raining the windows and screens completely fog over after about 5-10mins – when the compressor drops out there’s no drying of cabin air. A window must be opened because it sometimes takes 10+minutes before the compressor kicks in again.
With 525g of R134A freshly inserted (we now don’t think it was low) the low side sat at 90psi with the needle fluctuating down to 85 every 3-4 seconds, like it was trying to start – or is this what we see normally as it needs to produce minimum 2% for lubrication??
The pressure starts to drop to 30-32psi within 30-40 seconds. I would class this as high output – top vent temp according to VCDS 6-7 degrees – thermometer agrees.
I can see the compressor load with VCDS and it ramps up as vent temp comes down which seems normal. However, when the car is started it does nothing for about 30-40sec. During this period the HVAC ecu could be sending a medium request??? Can anyone confirm what their compressor load does after starting?
So is it the PWM solenoid in the compressor (new compressor required), or the HVAC controller in the dash?? I’m not sure exactly which parameter is the request to the compressor – I’m sure it is a PWM signal so I would expect to see either a 1-12v or 2-100% -
any ideas please.
any ideas please.
