Slow death of a 118TSI
  • #16
    I like it...
    You've got bigger cojones than me that's for sure
    VW Tiguan 110TSI Life | Tungsten Silver
    • #17
      lol Thanks, but my Mrs tends to think I'm missing a few brain cells instead!
      Here's a few pics from today's effort...
      I am really glad I didn't give it to WV to install. This is the the replacement engine with the head off!! The rust on the walls was insane!
      Bottom end...
      Lifters, valves and springs... All this will be replaced too.
      End result. Acid bath next. Undecided on what colour to paint the block.
      • #18
        I hope your current ECU file has been upgraded to a newer version. They used to run very close to lambda 1 everywhere I think only a couple of cells were like .92 or similar. Terrible. All the latest files are fine or at least not insanely lean
        https://www.youtube.com/user/oz04sti
        https://www.facebook.com/RecodeTuning
        • #19
          Current versions of ECU mapping and spark plugs, and of course 98RON may have avoided this.
          '07 Transporter 1.9 TDI
          '01 Beetle 2.0
          • #20
            I have a brand new long motor for sale if your after one! Drop me a PM.
            Volks Handy
            • #21
              I am SO glad we got rid of our 118TSI wagon, after new engines, clutches, wheel bearings etc, even if it cost us $30K to upgrade to a diesel Mk7 wagon!
              • #22
                Ouch, now the images have been fixed, that ran so lean! I had an old Datto in the 90s and cracked a couple of pistons, it was white like that...(running twin Webbers, compression ratio too high also).
                Manual MY12 RB Golf R | Bluefin Stg2 | Milltek turbo-back
                • #23
                  quick update
                  Quick update: Decided to give the rusty replacement engine an electolysis bath to try and remove the rust from the cylinder walls without scrubbing.
                  The result was not what I wanted, but definitely surprising!!
                  • #24
                    Can one tell if an engine is running lean before any warning lights pop up???
                    Also, how does the white residue imply running lean?
                    • #25
                      Subscribed. Good luck!
                      Can you link to where you read about the improvements VW has done to this engine over the years? I have a CAVD from 2012 and I always wonder how long it will last. Currently doing 72,000 km.
                      • #26
                        I have logged newer model twin charged vehicles and found them to run down well into the 11:1 a/f which should be nice & safe.
                        Volks Handy
                        • #27
                          Get someone with a VCDS cable who knows how to use it and go log your lambda values on some full throttle runs.'or take the car to a dyno and get them to log your a/f ratios with the sniffer up the exhaust pipe. The dyno method isnt quite as accurace but will give you a reasonable idea.
                          From memory the white residue is due to excessive nitrogen being produced due to the lean fuel mixture and excessive heat. Basically that white powder look is not good.
                          B9 Audi SQ5
                          • #28
                            Thanks. I have VCDS.
                            • #29
                              Subd... I'm considering changing my sparks because they havnt been done in a while and I just hit 100000
                              • #30
                                I think the recommended interval for that engine is 60,000km. At the most it will be 90,000km.
