Central locking problems 90 tsi
  • Central locking problems 90 tsi
    Hi everyone my wife,s golf is playing up ,the central locking button won,t always unlock the doors
    it locks the doors fine ,everything works fine with the remotes . It probably started 2 to 3 weeks
    ago and has been getting worse .
    Would it be safe to presume a faulty switch and if so is it easy to replace yourself ,does the doorskin
    have to come of or does the switch pop out from the top .
    Any help is much appreciated
    Thanks Theo
    Warranty finished?
    try for goodwill.
      Presuming you've tried changing the battery in the remote?
      2015 Audi SQ5 - SOLD
      New car incoming...
        Does unlocking via the door switch always work, or does that too exhibit an intermittent fault?
        When it doesn't work, do you hear any noises at all?
          It's the door switch that's the problem it locks the doors fine but wont always unlock them ,there's no clunk when it doesn't work as it normally does when central locking works correctly
          Thanks Theo
            Check the wiring where it passes through the rubber tube from jamb to door. It's finally been redesigned in the Mk 7.
              Will definitely check that thanks
