G-8VXWWTRHPN Golf R louder... - VWWatercooled Australia
Golf R louder...
  • Golf R louder...
    Hi Guys,
    When my R is cold and idling, it sounds very loud, I actually quite like the sound (I suppose you could say it sounds raw). But then after it begins to heat up it becomes much quieter, I'd like to know what causes this?
    I know it's not the flap in the exhaust, since I originally thought it was and I've disconnected the vacuum hose going to it.
    Any ideas??
    Sent from my iPad using Tapatalk HD
    2020 VW Golf R
    Some kind of catalyst warm up cycle. But from what I have read it is just running richer which wouldn't account for the sound change also...
    Sent from my GT-N7105 using Tapatalk 4 Beta
    Manual MY12 RB Golf R | Bluefin Stg2 | Milltek turbo-back
      My tsi does this, I just assumed it was the waste gate staying open while the cars rrvs are up when cold
      Sent from my banana phone
        Golf R louder...
        Call normal mine does it sounds almost diesel. Worse in winter
        Sent from my iPhone using Tapatalk 2
          Golf R louder...
          See my post on the other forum.
            I've noticed that from cold the ECU map for warm-up it will raise the idle (you might notice on the rpm gauge) and enrich the fuel (you can smell it). This puts the engine RPM at an acoustic sweet spot which makes it sound boomy. Remembering also there's that stupid sound actuator mirroring the engine rpm. The combined effect is the boomy sound you hear. You can use your foot and raise the idle to the same level and get the same effect.
            /10c
