Water pump issues on R?
    Originally posted by AdamD View Post
    Everything seem above board? Don't forget you'll need to run in the engine, just as if the car was new!
    Yea i know, it's a bit annoying! Already ran it in slowly and was going to take it to the track before it exploded.
    On a side note, since I have a new engine do I follow the service interval as before or do i start over?
      Also everything does seem to run in order.
      The VW dealership dealing with the case were pretty good, I had phone updates at least twice a week and had a free loan car.
        Good question - it'll depend to some extent on how much is new, and how many parts they just swapped over. Eg if spark plugs, coils, etc etc were all carried over, then the replacement interval for those won't change. Might be worth asking the dealer exactly what is included in a new crate engine, and what was carried over.
        To be honest though, there's not too much major engine servicing work that needs to be done on a newish engine. VW don't even regulate a run-in oil change period for a new engine (just change it after 1 year/15,000km, as per the standard servicing schedule), so there will likely not be a need for any major deviation for a few years yet - if at all.
        The dealer may have carried out a minor service on the car whilst it was getting a new engine. Most of that is engine oil, other misc fluids, and checking wear on key items (pads etc).
          Continue with the service schedule mate, don't start off. Some new VW engines come with spark plugs etc, some don't. Fuel filter doesn't get changed, brake fluid doesn't, DSG oil doesn't etc etc. The only thing that will be new will be the engine oil... All the other serviceable items don't get replaced, safer to stick with the current schedule you were on and just ask your dealer if the new engine came with new spark plugs (which it should have) then just note that down and do them accordingly. Goodluck.
            All helpful advice appreciated thanks!
              A week ago I found a large puddle of coolant near my Golf R's front passenger wheel. The coolant reservoir is completely empty.
              I've got about 25k kms on the clock and the car is nearly 3 years old. With only a month of warranty left I'm hoping this isn't going to be a serious problem. I need to wait at least 2 weeks before my car can be booked for warranty repair. Talking to my nearest service centre and VW customer care the only way to expedite is to get it towed by VWAssist but they can't give me an indicative ETA of when the car will be worked on once towed to the service centre. To be honest I'm quite disappointed that this has happened surely coolant is something which should just work.
                My Mk6 GTI had two water pumps replaced under warranty. The plastic housing can warp, resulting in a slow leak. Nearly a full day's labour to remove and refit so you're lucky it's a warranty job. Perhaps ask for a loan car and drop it off asap. They might get a cancelled job and do it sooner if it's under their nose.
                  You have now!
                  Originally posted by Lucas_R View Post
                  Never heard of any water pump issues on the Golf R here in Australia, although local GTI's have had a fair few problems with water pumps.
                  My Scirocco water pump let go with 6,000 soft KM travelled. Bent valves, new head on order VW new about it and were swapping out all pumps on 2012 build Golf R's, same platform as the Roc' of course. NO arguement from the dealer, they've been good about it and new the water pumps were defect from the factory.
                    Water pump on my 2011 Golf R was on the borderline, it made a high pitch whining noise when warm, had it replaced at a prominent vw specialist in east brisbane area ONLY because the seller had promised to cover the noise fix that had initially been misdiagnosed as something else... but once finding out it would cost much more it was not fair for him to cover the costs.
                    Honestly i should have taken it to a vw dealership knowing there have been a few cases before but the car was already at that particular workshop... waterpump was replaced and the noise went away and i paid more in labour compared to what vw robina had charged my friend plus i get marks on my front right wheel bolt holes and scraped paint under the engine mount. Seems like a rough cowboy method of water pump.removal... not too happy and although i have 2 vw's and likely to buy a bmw in the next 2 years, that audi vw bmw specialist is now out of my option to touch my car forever!
                    MINI Cooper S Clubman - FWD
                      And they didnt tell.me about the marks left on the wheel until i found out myself at home!!
                      Me and a few friends also wont be using that workshop anymore.
                        There is a campaign here in Australia for this issue. Not all R's are effected, mostly Sciroccos are the ones who have copped it. Have seen two pumps replaced as part of the campaign and have seen 0 engine failures.
                        Volks Handy
