7 speed DSG service?
  • 7 speed DSG service?
    i just had my car repaired by barloworld mascot, and whilst there i was told my car needs a DSG service ( 118 tsi with 60k on it) by the service technician. i had the car serviced 2 weeks ago by an independant mechanic. the mechanic here says the 7 speed DSG doesnt need a service, and he did change the gear oil for it at the service.
    so im not sure who is right, can anyone here clarify if the dsg needs a service? i was quoted 500 to have it done.
    thanks
    The 7 spd gear oil is not scheduled, not even under harsh operating conditions (short trips, stationary city traffic etc.) ....... Oil and filter is only the 6 spd.
    VAG Maintenance Manual
    Time or distance dependent additional work ........................... Interval
    Dual clutch gearbox (DSG) 02E: Renew gear oil and filter .............. Every 60,000 km
    • Not valid for 7-speed dual clutch gearbox 0AM
    And there is nothing specific in the Workshop Manual for extra scheduled activities on 7 spd..
    Asking what they want to do won't cost you, then you can decide if you want to play with them.
    VW SCIROCCO 1.4TSI - DSG (MY2010) UK, East Cheshire.
    Build Complete October Wk43/09, Driving 4th November - Wk44/09. Sorted !
      A DSG software update perhaps (but that won't cost anything (substantial)), but if someone's trying to get you to pay for a DSG oil change for your 7-speed, kindly ask him to jump into the nearest lake.
      Audi A3
        Guys
        Cant find this anywhere in my manual...when you refer 'VAG Maintenance manual', is that the manual that comes with the car?(sorry for stupid question! I've been trawling through my books and cannot find it anywhere!)
        Thanks!
        09 Golf 118TSI DSG
        White
        Adaptive Chassis Control
          Service book should be one of the first books in your "manual" folder thingo in the glovebox. Will have dealer stamps in it for services already completed.
          Audi A3
            Got the service book, no where does it mention...
            Have confirmed with 2 dealers though, dsg service not required (at 60k at least)
            09 Golf 118TSI DSG
            White
              Service book might be different for owners of the TDI and GTI, R, etc. The rest of my manual had generic instructions for other types of Golf's though (diesel warnings, etc).
              Audi A3
                The 7-speed DSG have no service schedule. The gear oil can be changed if you like, but the mechatronics oil has no set change period and the oil is not available as a spare part
                  I was in this position about a month ago. 2 dealers quoted me DSG Service for my 90TSI. Went to independent and who said it didn't need one. Pretty pathetic for the dealership service centres to not know that....
                    To change the fluid in the 7sp DSG you need only 1.7L Gear oil, the Penrite Manual Gear Oil70 is suitable, so it shouldn't be expensive. VW has a track record of whatever component they say it's filled for life (lifetime fill), the life of it is not very long. Most likely 5years/120,000km.
                    I'm from old school and change the oil in everything that has the drain plug on regular basis. The transmissions (incl. diffs) are run in between 10,000km - 20,000kmfrom new and require oil change regardless. But, if you keep your car for only for 3-5 years than do what is in the servicing schedule. Here is the link to service schedule in my post; http://www.vwwatercooled.com/forums/...tml#post684429 to clear up some confusions.
                    Performance Tunes from $850
                    Wrecking RS OCTAVIA 2 Link
                      There are two fluids used for the 7-speed 0AM gearbox:
                      You have 1.7 l of gear oil for the gearbox itself, which can be drained and refilled. VW says this oil is filled for life.
                      Then you have 1.0 l of hydraulic fluid for the mechatronics unit, which can be drained but not refilled - so leave well alone!!
                      For anything related to the DSG gearbox, I'd only ever use the OEM fluid - especially if the car is still under warranty.
                        You can refill the mechatronics (you are correct, it uses the reglar Pentosin hydrauic fluid) - the fill plug is at the top. We have had to do a few mechatronics changes in our 7 speed DSG program. You must drain 100% & use exactly 1 litre to fill.
                          Funny you say that Guy.
                          At dealership there is no provision to drain or fill the 7 speed mechatronics (although i know it would be possible as you found out yourself)
                          If any oil is lost from the mechatronics, only option is to replace.
                          Which strikes me as stupid. But i guess they may eventually do it.
                          I query why you've had to do a few changes as part of your 'program'?
                            So would I.
                            But hey, I know how some people like to use anything else but VW approved, especially when it comes to the engine oils.
                            For the mechatronics unit, Penrite says LDAS fluid, which is hydraulic fluid also used in suspensions and power steerings.
                            ...and yes the transmission fluids always need to be 100% drained, they're not as compatible as engine oils, but not all engine oils are compatible either.
                              It's a funny way we learnt actually, we purchased Golf & Polo transmissions from Europe for R&D, and when they shipped them, they drained 100% of all the oil (including the mechatronics units), so we found out the hard way on the first one
                              When VW ship them, they fill them & seal them with a cap over the vent plug I believe.
