Noise when turning off car after a decent run
  • Noise when turning off car after a decent run
    Hi,
    Just started this. After a run of say 50 or more kms, when turning my car off, I know I sometimes hear the fan in the engine bay running for a while, but recently it's starting to sound like a flock of seagulls under there! Particularly so on a warmer day, and we've had a few in Perth recently. As I say, it's after a good run, primarily when hot.
    I actually took audio of this noise with my iPhone's recorder to play the service guys!
    Thoughts? Worries? My 15000 service is due in about a month or so, wait til then, or get it in earlier? Thanks.
    Rgds
    Rod
    WHITE 118FSI DSG MY12 Sports Pack with RNS510 Sat Nav - PICKUP Oct 17, 2011. Added Chrome bootlid spear-very nice, Golf doorsill protectors-not so nice and Aluminium Pedal set-EXTREMELY nice!
    I get the same fan noise- it can last for up to ten minutes. Had it on the weekend after a similar run, in ~30c heat.
    Pretty normal for the car in my experience!
      Originally posted by Roddy View Post
      Hi,
      Rgds
      Rod
      It's just the car cooling down some of the components and circulating oil to the turbo etc. nothing to worry about.
      Golf MK VI Silverleaf 118TSI
      Installed
      |APR Stage 1 |MDI| RNS 510| K&N 57S series Intake|Golf R32 Pedals| | Audi S3 Intercooler | Detroits|
        Is normal
        Audi A3
          This is perfectly normal. It keeps the fan going to prevent heat soak.
            It's definately normal.
            Although it seems random, as it doesn't happen all the time, it will only do it if certain parameters are met. Such as ambient temperature, engine temperature, and drive time.
            Don't stress about battery voltage, if it falls too low, the whole sequence wont happen.
              The Golf has a very powerful battery. I've run the RNS510 for over an hour just on battery (updating firmware, reloading maps and music, have also watched DVDs for a long time on battery).
              The cool down mode shouldn't last more than 20 minutes top.
              Audi A3
                After a quick RNP cruise the fan was on for 5 mins after switched off - just need some cool air
                Golf Mk6 118TSI MY11 | UG | DSG | RCD510 | Dynaudio | MDI | Park Assist | Sport Pack | Opti-coat
                  " it's after a good run, primarily when hot."
                  Not sure about all Golf models but with the GTI and R there is an auxiliary water pump (electrical) that circulates water in the opposite direction to the mechanical water pump after you stop. It runs cooler water through the turbo and engine after you stop so that the heat sink doesn't damage turbo bearind etc. I believe it can run for up to 15 min but I'm assuming it's all dependant on a number of temperature readings at the time of engine shut down.
                  I came across the diagram of the pump and it's reverse circulation some time back. Didn't keep a copy. A quick google may find teh diagram. IIRC it was in a VW training dcoument.
                  Golf R RB 5D DSG
                  Mods - Garage Door Opener, Chrome Mats, Fluffy Dice DSG Paddles
                    Spot-on.
                    Quite a few VWs have them now.
                      Ah, so that's what the part I replaced last weekend does (tiny leak/seeping)
                      Audi A3
                        Automatic turbo timer
                        Tiguan Gen2 162TSI Etuners IS38 Stage 3 238.6 kw@4 wheels
