Mystery leak, experience/advice sought
  • Mystery leak, experience/advice sought
    Evening,
    Am trying to solve a mystery leak that's popped up over the past few weeks, which reoccurs on a regular basis. Am driving a 2010 MKVI GTI.
    Occurence:
    - Most times I stop the car, or start moving with a reasonable level of brake force (i.e. stopping in my street to reverse up the driveway), I notice that there's a very small pool of liquid on the ground where I stopped.
    - If I stopped and started reversing/driving quickly, the pool is in a line, so it's a leak when there are G-forces on the car.
    Fluid:
    - The leak is clear, and I've mopped it up and checked it out on multiple ocasions.
    - Smells like stale water, looks like stale water, with a hint of chemical.
    - If left on the road, it evaporates completely after a few minutes.
    - I think? it's water.
    Narrowing things down:
    - It's not radiator fluid, as that's a purple colour, and over the last few weeks, I've confirmed no change in level. Also smells entirely different.
    - It's not windscreen wiper fluid, as I use the VW solution in mine, and that has a distinctive smell. Also, the anti-freeze in that would prevent evaporation?
    - It's not engine oil, due to the colour/smell/evaporation.
    Other information:
    - On occasion, it looks like there's a bit of water inside the engine bay (right at the bottom, in about the right quantities), but it hasn't been raining on that day / etc.
    Theories:
    - I have two theories right now.
    1. There's a leak inside the engine, due to a crack / etc, which I would love some clarification on! Also, if water's leaking, where is it coming from?
    2. On the other hand, it could be from the windscreen's drainage channels being blocked, and going a little funny? I don't know enough about how they work though.
    Any help would be appreciated!
    Is it condensation leaking from you air conditioning pipes?
    Sounds like it to me. It's perfectly normal by the way for it to drip on the road when you have the a/c running.
      Sounds like aircon fluid to me
        My old car (not a VW) did this. It was the aircon
          I'm 100% this is condensation from your AC drain.
            Yeah just condensation that has accumalated in the normal processes of your air conditioner. Quite normal, will probably be worse on a humid day as the A/C removes moisture from the air.
            GTI MY16.5 PURE WHITE | LAKIN PLATE HOLDER | TINTS |
              Panic bro, your flux capacitor is running out of Noonie juice!
                Thanks guys, appreciate the advice! Was getting worried it was the water pump or sumfin'
                  Now go out and do some celebratory skids.
                    Reverse burnouts with the AC on Max to celebrate?
                    There'll be two lines of rubber, and one in the middle of an indistinguishable fluid - legit :p
                      Tutorial:
                      Golf 3 VR6 Kompressor Burn Out - YouTube
                        And Ryan, the more humid the weather, the more condensation you will we get.
                        Has not been a 'typical dry Canberra summer' at all "Innit"!
                        MK6 MY10 Golf GTI, 5dr Manual, Carbon Steel, Detroits, Tint
                        T6 MY06 Peugeot 307 HDi Touring, Manual, Iron Grey, Tint
                          i think you'll find like everyone else had said that its just condensation from AC. Ive found on some VAG vehicle that the drain doesnt drop directly onto the floor but it drops on top of the right hand under tray then drips off that. So alot of water would be getting trapped in there.
                          Also your AC pipe sits over the chassis rail, so theres no reason the water couldnt be dripping there and getting stuck in there.
                            Very true!
                            Although I thought my driving style may have aggrevated the situation. Am relieved now at any rate!
