DRL standard Halogens not working
  • DRL standard Halogens not working
    Hi all,
    Sorry if this has been posted before I did a search for "DRL not working" but got 17 pages of nothing.
    Here's the story.
    I have a GTI with halogens, my lights are set for auto and in the past say up until a week ago the "DRL" / parkers have always been on. Thursday this week it was overcast and yet there was no lights on at all not even the "DRL" / "parkers" I have in the MDF under lights got the DRL option ticked. I've unticked and retick it to see if it turns it back on.
    Anyone had this problem in the past and if so how do you fix it. I like to have the lights on all the time.
    You do have the switch on "Auto"? and have you checked the procedure in the manual?
      How old is your GTI? At one point the controller was updated to allow the DRLs to be switched on and off direct from the MFD (mine, as an MY10, requires a different procedure). It sounds like you have a later model, so perhaps trying the original technique (should be documented in your owner's manual too) will do the trick.
        MY11. I have check the manual and even tried their push and hold indicator right while high beam flash. My coming home lights are also off.
        As said in first post everything is set to auto
          Fuse blown or dodgy wire/connector perhaps? Otherwise, just take it to VW to get looked at under warranty.
            I've even followed other forums advise and cant get it to work...
            DRL disable/enable without VAGCOM - VW GTI MKVI Forum / VW Golf R Forum / VW Golf MKVI Forum / VW GTI Forum - Golfmk6.com
              So I have today spent just on an hour at a VW dealership today and it looks like there maybe an electrical issue. The workshop activated the DRLs but couldn't get them to work. I also don't have any parkers either....
