From page 167 of my GTI Owner's Manual, under Manual Gearbox: "Do not rest your hand on the gear lever when driving. The pressure from your hand is passed onto the selector forks in the gearbox". Very
Thanks, Tim, and sorry for my obvious ignorance. I have been driving manual cars for 36 years and rebuilt quite a few cars and motorbikes but have never thought resting my hand on the gear lever transmits any pressure through to the selector forks. I learn something new every day.
I too have read things along those lines for years and wondered what the real impact is of resting your hand on the shifter??
Can anyone who has seen any damage comment or better yet post pictures?
I've stripped and repaired some Eaton Roadranger 15 and 18 speed transmissions out of trucks and you can tell a lot from the wear patterns on the internal components. The shift forks can show a groove or witness markings on one side if a driver holds the gear lever constantly. Even a small amount of pressure that you probably don't realize that you are using is enough to push the shift fork (via the gear lever) onto one side of the shifting dog and wear occurs. It looks like a groove in the metal on one side. You can also tell if someone has not been using the clutch as it wears the face of the gears. This rather shaky video shows the forks at around 1min 35sec. (counts backwards??)
Bigger gearbox, similar principle.
sigpic GTI MY16.5 PURE WHITE | LAKIN PLATE HOLDER | TINTS |
Thank you Ozram. Nice to get an authoritative answer.
sdhog2002,
Its not going to cause an immediate failure but over time it can make the gear lever action loose and eventually lead to gear changing problems. My Dad always used to say that when he was learning to drive the instructer had a wooden ruler and would rap him over the knuckles if he left his hand on the gear lever and also his thigh if he left his foot on the clutch.
In a similar vein, I saw a brand new Holden Cruze being driven the other day and the guy had his foot resting on the brake pedal all the time as his brakelights were blinding me. I see that happening more frequently. Some people must have bottomless pockets for the repair & servicing costs involved with doing that.
Ford's C6AZ-19542 brake fluid was developed in the early 1960's to prevent some US car owners from boiling their brake fluid when they did this. It turned out to be a fine racing product.
Sometimes, people get too insulated from their own mistakes
Resident grumpy old fart VW - Metallic Paint, Radial Tyres, Laminated Windscreen, Electric Windows, VW Alloy Wheels, Variable Geometry Exhaust Driven Supercharger, Direct Unit Fuel Injection, Adiabatic Ignition, MacPherson Struts front, Torsion Beam rear, Coil Springs, Hydraulic Dampers, Front Anti-Roll Bar, Disc Brakes, Bosch ECU, ABS
I guess if you're taking off from the lights, and you're shifting from 1st, 2nd 3rd maybe 4th within a 6 second period, then you might be excused for not returning your hand to the steering wheel.
but resting it there any other time clearly reduces your ability to control the vehicle.
I agree Ozram, there are definately lot of bad habits around the place.
The taxis that i've been in lately, seem to accelerate and brake repeatedly, (every 3-5seconds) instead of feathering the throttle to maintain a constant speed.
I can't imagine the wear on brakes, and fuel wastage from this.
the first time i experienced it, i thought the driver was tired, but now i've had the same experience in many cabs.
2010 Golf R - 3dr - Manual - Rising Blue - MDI - SatNav - Milltek TBE
Taxi drivers are notorius for being hard on their cars - a friend who used to work for Borg Warner told me a hilarious story about a driver who was so bad that they logged his inputs and used it for testing their gearboxes because it was harder on the components than anything their engineering team could devise.
Apparently, the log escaped to vehicle manufacturers for testing their engines, drivetrains and brakes because of the same reason
While I've seen some really bad drivers, I'd think that the manufacturer of the car would have better break testing than a taxi driver. There was a documentary many years ago about the making of the VB commodore that showed how Holden tested the auto. A test driver on a large concret area with his foot on the brake (gently) to hold the front while at full throttle in a 308 trimatic, rear wheels smoking, changing from drive to reverse and valve bouncing the engine. According to the commentator, they would do this for hours at a time, then pull things apart to see what this accelerated wear was doing.
I'm sure similar testing is done in laboroatories before they sell the boxes to car makers.
Candy White Golf GTI Adidas with Park Assist and Reversing Camera
Engineers will devise harsh tests in a systematic way but users (in this case drivers) can operate systems in a manner that will not make sense to those who design or regularly consult with the designers of systems (ask anyone in IT support/development).
The story I relayed was told to me by one of the engineers involved who couldn't figure out how their new flagship gearbox was failing so quickly in real world testing. The driver used for their rollout test was not random - they asked a taxi company to specifically assign the car with the new gearbox to the driver with the worst maintenance record.
They only logged the driver's inputs (without telling him that they were doing so) after about 3 gearbox failures and when they played back the inputs on their test rig (with idle time edited out), they thought the system was malfunctioning due to the apparent randomness and savagery of the throttle/shift/brake operations. Detailed checks of the test system and comparison of the test input recording vs the original logged inputs showed that system was faithfully reproducing the actions of the driver.
Truth (actual driver usage in this case) can be stranger than fiction (test schemes devised by design/QA departments)
Sorry, wasn't having a go at you - far from it - I'm just amazed that given the stupid things they do to cars in testing are not enough when you see the punishment they go through. Seems pointless to devise a 'harsh test in a sympathetic way' - but having attended a 5 day 'software testing workshop' where the lecturer insisted that testers ignore what the progammers say is the way to test things (and my team managed to break things by ignoring what the progammers said).... I guess I should be less sceptical.
What is does sound like though is that the car maker ask for a high enough spec box for their product. Seems to be the case for most failures of things outsourced. I'd love to see some footage of what this driver was doing to be that savage - must have been driving it like a rental car all the time.
