Is it possible to change the lane change flash so that it performs more than 3 lane change blinks?
Lane change flash - more than 3 blinks?
I have seen this discussed before here. I believe that you can't change the "lane change flash" in your settings.....so be like me, see it as a challenge to get your lane change done before the 3rd flash.
*that will stir up some purists*MY16 Touareg 4.2Lt V8 TDI/Pure White LED lightbox/REDARC Brake Controller/ Racechip/iDrive Throttle controller
2008 GOLF .:R32/5DR DBPE DSG/SUNROOF/RNS510/PRIVACY TINT/CONTI SC3s/MILLTEK CATBACK NON-RES/9W2 BT/"MYR-032"
I'm sure many drivers would rather see you change lanes in a controlled and safe manner rather than trying to beat the "3 flashes"."Stupidity is the only universal capital crime; the sentence is death. There is no appeal, and execution is carried out automatically and without pity" R. Heinlein: Time Enough For Love
See this thread on VWVortex.Originally posted by hooba View PostIs it possible to change the lane change flash so that it performs more than 3 lane change blinks?
I don't use it myself. Prefer full control over my indicators, but each to their own!Originally posted by VWVortexComfort Turn signals
Found in Adaptation. From the drop down list, choose the number of flashes and Save.
As others have said. The "Comfort Turn" signals can be enabled or disabled in the MFD setup menu. If you need more than 3 signals for a particular maneuver then you can "hold" the indicator for the additional blinks. However, you can use VCDS to update it to either 4 or 5 blinks
Many thanks for your help, that link has been saved.Originally posted by AdamD View PostSee this thread on VWVortex.
Now I just need to find a friendly VCDS guru in Sydney...--------------------------
I think minimum is 3 and maximum is 5 - that was the range accepted by the controller... from memory when I was in that controller section....
But... c'mon - 1 flash... isn't it what the rest of other drivers are doing anyway when changing lane? mostly here in Melbourne...
I changed mine to 4 about 2 weeks ago - much better.
(The only annoying thing is if you accidentally indicate while turning on cruise control) :p
I'm guessing that changing the 3 lane flash as well as the Auto Sunroof Closing when raining (as per the other thread) will all have to be activated in the Golf R also. Is it a time consuming process using the VAG-COM or could it be something you could request the dealer to do when you go to collect your new car?MY11 Golf R - Rising Blue - 5DR - DSG - 19" Black OZ Ultralegerra - Leather - Sunroof - MDI - Euro Plates - Milltek Exhaust - Bluefin - SOLD
MY11 Tiguan 147 TSI - DSG - Pepper Grey - Black Leather - RVC - MDI - BT
