I've been told that you'll be able to feel the engine vibrations a lot more through the seat of the car - something not really desirable in a smooth and refined car like the golf. This is why I'm reluctant to install mine - I'll probably install mine at the next service and if its bad I'll just take it out.
2007 Black Magic VW Golf GT TDi, Latte Leather, Sunroof, Bluefin Superchip, 18" Detroits, APR lower torque arm insert, APR Carbon Fibre Cold Air Intake system, GTi sideskirts & front lip, R32 Rear Bar, GTi Steering wheel, RNS-510,Infinity BassLink Subwoofer,stubby antenna, R8 Oil Cap, Golf R front calipers, slotted front rotors, ceramic brake pads, LITEC LED tail-lights, Dension Gateway Five, Rear Emblem Reverse Camera, H&R Ultralow coil-overs, Badge-less front grille
The APR Torque Arm Mount Insert is inserted to the existing engine mount, which greatly reduces driveline shock and drivetrain slack, resulting in improved power transfer. It also enhances upshifting and downshifting.
I don't know if you've seen someone revving their car whilst the bonnet is open... or doing a dyno run etc. When you step on the accelerator, the entire engine moves (even when the car is stationary). So I guess changing this increases the forces required for the engine to move, to achieve those advantages above. However, in doing so it means that more engine/drivetrain vibration can be felt in the cabin - so there is a balance required.
There are other forum memers who have this installed (especially Polo GTI owners), so maybe you can do a search in that forum to see the comments from people who actually have them installed
ah i see.... i didnt quite understand the 'drivetrain slack' but now i do... thanks for that....
probably not worth it on the gti mk6 then, ill save my pennies for an APR exhaust upgrade then (is it bad that im thinking of upgrading even though i havnt even got the car yet?!?!)
