118TSI Stalled
  • 118TSI Stalled
    I lost drive in DSG and the golf didn't move- then stalled out.
    WTF is going on???
    Also on another note, my supercharger has lost it's squeal/chirp...
    Going to speak to the delaership later.
    Did you get the dealer update for the 118TSI????
    Also could be the mechatronic unit for the DSG as i have heard of them going and losing drive.
      Hmm.. Not good...
      11:44 13/7 Dealer hasn't heard of this happening before... Service manager will call me.
      After I restarted it, there was no drive asin I out the pedal down and nothing happened, shifted to N then back to D, had drive, drove off.
      Noticed my squeal wasn't there, so drove around abit replicating the conditions I used to get the squeal (4th in M mode and about 40kmh) and nothing. Dropped it into S mode, Changed alright but when in S2 and booted, S1 would take about 1-1.5sec before it would engage and then would take off. I don't know if this is because the blower isn't working/spooling up properly and the NA is crap until the turbo kicks in, but not a good thing!
      Update was postponed as they didn't have the available service spots to do it.
        14:29 Car booked in for the 28th, for a roadtest and diagnostic. Upgrade will be done then.
        No courtesy car till Sept! Crap!!!
          That's no good mate! So they won't even have a quick look at it today or tomorrow and run diagnostics on it?
          MY20 Golf GTI TCR
          MY20.5 LR Defender P400 HSE
            No, as it was the first time it's happened. I'll see what happens on the way home tonight.
              Update.
              Seems like the supercharger clutch is slipping at times. I had lag from 2-3k, then the turbo came in. Something is definately not right.
                Perhaps there is a fault that has disabled your supercharger altogether! Hence the lack of chirp and GTI like lag on getting your low revs boost If it was a major problem you will probably get a warning light of some sort (EPC), so thats positive. Shame you cannot find someone nearby with VCDS to plug in and take peek at what is flagged. If you turn your IGN on, Eng not running, (in a quiet location) and pop the bonnet, can you still hear the constant high freq whine from the supercharger regulating flap motor? Sound should emanate from the rear centre of the engine cover. If not - Good chance it is disabled.
                Golf Mk6 118 TSI DSG |APR Stage I ECU Upgrade | HEX-USB+CAN
                  Chirp came back last night and the lag disappeared.
                  Logger, the whine is there now, but I don't know if it wasn't there before. My worry is it's going to be one of those intermittent things that shows up only when the techie isn't in the car with me or on the extended test drive!
                    Possible - but any fault will be stored in the system as a fault occurrence, even though "the issue" has gone away for the time being.
                    I just had a quick play with mine and disabling the supercharger clutch electronically does not remove the whine. However disabling the regulating flap does remove the whine which makes sense because that is what is whining. Disabling the regulating flap is sensed by the car which in turn faults the system and disables the clutch.
                    Disabling by either method prevents the supercharger running AND generates stored fault messages.
                      Would this come up on a scangauge?
                        Hey log, did you by chance try driving it with the supercharger 'switched off'? Wondered what it would be like thats all.
                        Noticed sometime the supercharger kicks in a little premmie at highway speeds on hills, wondering if disabling this on long drives would lower my fuel usage lol.... That is if it's not bad for the car.
                        Stoney!
                        6 Sp Manual 118 TSi
                        Colour: United Grey
                        Build Date: August 09 Delivery Date: 16th Oct 09
                        ODO at last fill: 2555km
                        Avg Fuel Cons at last fill: 8.6
                          TBH.. I'd rather the turbo not be there and have the whine of the blower ala Italian Job!
                            Stoney!
                            Wouldn't a 118TSI with the supercharger disconnected simply be a 90TSI
                            2010 90TSI Manual / Comfort Pack / United Grey
                            RICE - Leave the useless wings to the Penguins...
                              118kW with terrible turbo lag
                              2018 Tiguan 110TSI Comfortline + DAP
