Mk6 Golf Acceleration & Performance Data
  • Corey, as a matter of interest what is the cost to replace a DSG box in the R?
    Golf R MY 11.5 United Gray, 3 door, DSG, ACC, Free MDI, Bluetooth
    Mods - APR Downpipe, VW Racing AI, HPFP, APR Tune Stage 2+- lovin it!
    Touareg V8 TDI R-Line, White .Arrived 11 July.
    • No idea. It wouldn't be cheap!
      Usually though you're not replacing the "gear" part. You're replacing the clutches (rare in the 6sp as they're bathed in oil) or you're replacing the mechatronics box which is on the side of the DSG box.
      • Ah yes, forgot about the staging part. Though if you got to the line first, ie before the other guy, it would buy a bit more time as it won't go green until he's moved forward as well?
        • Originally posted by Corey_R View Post
          Yeah.... I know re the staging time... but still, I want to beat them to the damn line damn it! hehe
          Yeah - it was very muggy tonight, I'd be sweating by the time I got my helmet off and rolled my sleeves up after the run.
          Oh, and for those who were wondering, you can disable the LED DRL's on the R so that the drag officials don't get upset at you! (thanks Sammy125TDi !!)
          Good times mate...
          As i said in the 1/4 mile thread.... don't worry about reaction times, big turbo auto trans guys will often wait 10-15 seconds with the green light lit up before they leave on boost.
          • Cheers!
            Having said that, on the way home I tried out some theories based on my findings last night and on what AdamD suggested.
            And I must say, AdamD was spot on.
            The quickest method to get into "Launch Control" is whilst you're in D, even if you're still moving, to press the ESP Off button. It needs about a 1 second press and that's all. Then when you come to a stand-still, keep the brake depressed, push the DSG lever into M or S, and you'll be able to rev up to ~3000rpm and take off by releasing the brake. Each time you then come back to a stand-still, you'll be able to rev and LC from the line again.
            If you're at a stand-still, then you roll forward a little bit (either in traffic, or at the lights, or at the pre-stage/stage lines on the dragstrip) and then go to rev but find it loads up against the brakes - keep the brake depressed, push the DSG level into D and then back into either M or S, and you'll be able to rev again.
            So in the case of the drag strip, make sure ESP is off before you go through the gates, and then leave it in D until you are "staged", then quickly put it into S, keep your foot on the brake until the revs are where you need and the lights are almost green, then release the brake and go!
            Hope that helps guys.
            • Good tip on the LC Corey. Curious on your 1/4 mile time, did you have traction problems off the line? What PSI were you running in your tyres also?
              MKV GTI Pirelli
              • Originally posted by bwen View Post
                lol traction problems in AWD... me thinks not...
                2011 Golf R MKVI | Candy White | 5 door | DSG | ACC | 19" Black rims | Vienna Leather Electric | RNS510 | Dynaudio | MY11 Bluetooth | Sunroof | Stage 1 APR Tune | On the road again...
                • I doubt there were traction issues - the haldex system handles even Stage 1 power fine. Plus my 60' time was really good. PSI were at 35. Next time I head down I'll have Stage II and hopefully not be so nervous. Maybe I'll have more spare brain-cycles to devote some to taking notice of things like initial traction! And a few more runs unhindered by LC engagement issues before it rains so that I can try different tyre pressures.
                    Yeah - I tried that, no joy. AdamD, when you get a chance, can you please let me know whether the red light on the button comes on when depressed regardless of whether the GTech is connected or not?
                    Sorry Corey, I was mistaken; the light turns on for me even if the cable isn't plugged into the back of the Gtech, as long as it's firmly pushed into the 12v socket. So unless you didn't have it seated right (and it needs a firm push), you might have a dodgy cable.
                    • Thanks for checking
                      • Yeah, just another thing if we are posting 1/4 mile times can we please get the tyre pressure too
                        Genuine VW Parts Importer | Navigation | Bluetooth |
                        Repairs | Lighting | Coding | Programming |Cameras
                        • Hey y'all.. So how did FAB and DaveR go?? Any times yet lads?
                          2010 MY11 GOLF R - 5DR | DSG | RISING BLUE | DYNAUDIO + ACC + BLUETOOTH + 19s + RNS510 |
                          2017 MY17 TIGUAN HIGHLINE - 5DR | DSG | PEARL BLACK | SUNROOF + DAP |
                          • In a word, disappointing.
                            Exactly half tank of fuel, driver only (no passenger)
                            Code:
                            Run	Gtech	PerformanceBox
                            1	5.25	5.6
                            2	5.02	5.2
                            3	5.36	5.7
                            4	5.09	5.4
                            Runs 2/4 being the return trip. Outside temp was around 18deg according to the MFD, didn't bother with any VCDS logging.
                            I was told to expect ~4.9 for an APR Stage 1 tune with the PerformanceBox from the APR dealer who did the tune. As you can see, the car isn't near those figures. Only stock figures I can find are the claimed 5.7, don't have any of the aussie mags near me to confirm their results.
                            And with LC, its pretty hard to get it wrong...
                            • Originally posted by dave_r View Post
                              Code:
                              1	5.25	5.6
                              2	5.02	5.2
                              3	5.36	5.7
                              4	5.09	5.4
                              Sorry to hear you're not seeing the numbers you'd like Dave. Still pretty decent - 5.2 is not hanging around, by any means, and it is three tenths better than what VW claims for the stocker. What was the ambient temperature for your runs?
                              Interesting to see the difference between the Gtech and the PerformanceBox too (although not surprising). The former does actually delay the starting timer to give you the maximum benefit of perfect staging (great excuse for slow response, hehe), and its GPS chip is only 10Hz so there's a significant issue with accuracy there too. I've got one of the latest Gtechs, and I'm sure that my best run was at least a couple of tenths optimistic.
                              One of the best ways to check how long the Gtech has taken to respond is to look at the detailed plot screen for the run, and see the speed and time for the first plot. If it says you're doing 10km/h inside of a tenth of a second, you know why the run under-read quite so much.
                              • Is this Fab_R's older non-GPS GTech unit?
