Static lights can only be activated using VCDS Found in Coding, Long Coding helper, Byte 14.
Only work with Headlights On or in Auto. The static turning lights come on either after you indicate, or when you turn the steering wheel about 90 degrees, And only if you are driving forward. If you are driving with your fog lights on... which is a heavy fine in most states! the static turning lights will not work as you have the fog lights turned on!!
