I have had a few problems with my now only 2 mth old 118TSI.
A small but irritating problem was the B Pillar clicking/ticking noise from both doors. It occured when the car was moving AND also not moving.
I've seen others on this forum have had the same issue but I haven't read if anyone has had this fixed?
Anyhow, the dealer fixed the noise for me by removing the B Pillar high gloss black plastic on each door and insulated with felt (or something similar).
It is now blissfully quiet!
I suspect it was just the upper part of the trim that required fixing as beforehand you could repeat the noise by pressing in the plastic on the upper edge of the door and hearing the clicking/ticking noise. The lower part was firm and quiet.
I hope this helps others with the same problem. If the problem is as common as it seems, VW should tell ALL its dealers how to fix as it would save us all a lot of time trying to explain to the service people, test driving etc.
