Eibach ProKit + Dynamic Chassis Control (DCC)
The post with the White 3 door DCC equipped GTI was to evidence that a small amount of lowering is possible with DCC. Long term, it’s unknown how DCC will cope with a slight drop in ride height.
Eibach ProKit – A few reasons I wouldn’t be rushing to install a set of progressive strut type aftermarket springs. Noise levels & spring bind would be the two biggest negatives. Progressive strut springs also create a hover craft type of feel with better ride, but a trade off in linear spring rate and driver feel. Progressive rate springs do create a fun factor in the drive with the changing spring rate keeping you guessing as to what the chassis will do. I’d prefer the linearity of the OE springs or the KW coilovers.
If I was to run Eibach ProKit Strut Springs again, I’d mate them with a set of Koni Std Reds or Bilstein Std Blacks (prob Koni for a better ride). KW Comfort Coilover would still be my first choice if I didn’t have DCC. When running the KW V3, friends would comment that when I got in the GTI, the ride height didn’t budge any lower, as would be the case with OE suspension or Eibach ProKit or similar strut type aftermarket spring.
Many owners of HSV GTS Commodores with Magnetic dampers have also managed to lower their rides @ 10-15mm – but not a lot of room to go lower with the HSV Magnatec.
Changing wheels on the MKV and MKVI Golf isn’t a drama so long as they are the same or very close to the OE 50mm offset.
The MK6 GTI sits a little lower than the MKV, esp at the front. Once the springs sag 5mm-10mm over time or you carry a passenger adding weight, or a combination of both, the MK6 GTI will look plenty low enough imo, esp given that the MK6 is designed to look wider & lower.
Me, I’m keeping mine stock as it is reasonably well sorted straight from the factory.
WJ
WJ
