H&R Coilovers
Can't see how Magnatec can be that complex. Tiny metal particles in the damper fluid with an electrical current changing viscosity of the fluid. Having said that, not sure how the Adaptive Chassis Control works ... I'm banking on ACC (DCC) having a small electric motor turning a valve with same/similar sensors as the magnatec working out the optimum damper rate in reaction to each bump on each individual wheel.
On the aftermarket front, should you wish to upgrade to a coilover, the wiring within the vehicle is in place if you wanted an electronic adjustable type of PASM Porsche style coilover that is adjustable on the fly from a controller within the vehicle. Sachs may offer an aftermarket coilover that may be a simple plug in substitute ... similar to changing or adding an aftermarket SATNAV system that can be linked to the steering wheel controls.
Another reason to look at ACC, rubbing on lower ride height with slightly wider offset (ET) aftermarket wheels as this thread suggests:
Question:
Why will this forum not allow me to post attachments?
Do I need any special permission?
WJ
Question:
WJ
