Dynamic / Adaptive chassis control (DCC / ACC)
  • #46
    Originally posted by Mk6 GTI View Post
    hehe yeah i guess they wouldnt be..
    One of the less obvious areas to cut costs!
    It's got nothing to do with costs (as you can see, in high volume, the Goodyear are cheaper than the Conti's anyway). It has to do with the contracts that a car manufactuer has with tyre manufacturers. For Volkswagen that's primarily Continental and Bridgestone, both of which make good tyres.
    It's just that right now, the Goodyear Eagle F1 Asymmetric is the best. Could be something else soon
    • #47
      cool, fair enough!
      2010 5 DR MK6 GTI|DSG|CARBON STEEL|18" DETROIT|ACC|BI-XENON|LEATHER|SUNROOF|DYNAUDIO|SATNAV|MDI|PREMIUM BT|TINTS|EXTENDED WARRANTY| In garage
      • #48
        Hi
        Well I placed the order today for our mk6 GTi .looking forward to when its up our drive way .
        Mk6 5Dr Candy white with Jackie on board , DSG , E/roof , Bi-xenon , RNS sat with Dyn , 18" Detroits , Acc , Full tint , MDI , RevC , BlueT , Towbar
        • #49
          Originally posted by elisiX View Post
          I dont believe they're fitting the Goodyear F1's.
          As far as i know, GY F1 asymmetrical aren't made/used for OEM tyre, so doubt they would fit it (score if they do).
          • #50
            Originally posted by MurphyTheElf View Post
            Mine came with Bridgestone Potenza.
            Hi M
            Which model Potenza are they .I have the RE001 fitted on my current car and they don't suffer from scolloping like the old G3's .
            • #51
              Originally posted by gtimal View Post
              Hi M
              They are RE050A.
              GTI MKVI Candy White | 5 door | DSG | ACC | 18" Detroits | Leather | Electric Seat | Sunroof | RNS510 | Dynaudio | Park Assist | RVC | MDI
              • #52
                They are RE050A.
                Thank God. The RE001's on my MkV are garbage in the dry and dangerous in the wet. Previously had Yokohama Advan Sport V103 and CSC2s, and I've heard the RE050A is up there with those 2 performance-wise.
                • #53
                  could you have a car with acc an coilovers? or acc is instead of coilovers?
                  Would i be better off not getting ACC an just buy a decent set of coilovers?
                  my-86.com - Blog about my Toyota 86 and some pics and stuff.
                  • #54
                    Well coilovers essentially replace your shocks and springs...
                    And yes I would just go for coilovers if you plan on adding aftermarket wheels and dropping a little (or a lot).
                    However if you plan to keep stock wheels, option ACC.
                    2019 BMW M3 CS
                    • #55
                      ACC or COILOVERS?
                      im purchasing a brand new golf.
                      im getting the 18 inch detroits.
                      should i get the ACC with the car or should i purchase coilovers later on if i want stiffer dampers.
                      the cost of ACC is almost same price as coilovers.
                      • #56
                        depends.
                        ACC I would think is for those people that dont want to compromise on daily comfort. Other than that a set of coilovers will allow you to pick a rideheight/damper setting that suits your usage.
                        For my personal taste id go with a good set of coilovers. But then i dont think its a decision that anyone else can make for you because it has to suit your set of requirements
                        FOLLOW US ON FACEBOOK
                        • #57
                          Depends if having the ACC on Sports mode is firm enough for you.
                          VW's tend to have a soft ride, so I'd think if you want track handling, you need track suspension.
                          • #58
                            well if i install ACC now, can i install coilovers later on? or there's gonna be alot of sensors dangling around?
                            • #59
                              I went with the 18's and no ACC because I expect to change my suspension to a coil over setup down the track (not for the track).
                              I think if you want the car stock ride height and wont change your wheels (but choose the optional 18's), you should pick up the ACC.
                              2019 BMW M3 CS
                              • #60
                                This is a question I've yet to see anyone answer on these forums. I'm not sure that anyone here has bought a car with ACC on it and tried this.
                                But I think that as Tim mentioned, it depends on YOU.
                                The ACC allows you to press 'sport' for when you want that firm suspension and handling, and press 'comfort' for when you're on crappy roads or in a car park with 50,000 speed humps between you and the exit etc.
                                Good coilovers are going to allow you to get better handling and fine tune the car the way you want. They're adjustable, but not DURING your drive. They would be far better on the track, and if you're a hoon, they'd be better on the road too
                                But lets face it, good coilovers are going to cost you far more than the $1500 of ACC. From what I can see the Sachs Coilovers for the GTI are about RRP $3000 plus installation. KW Variant 3 coilovers are likely to be even more. (Kryten001 might be able to post here how much he paid for them to be installed on his Pirelli)
