Originally posted by G-rig
View Post
DRL / Daytime Running Lights / Driving Lights
Thanks for the helpful advice!Originally posted by logger View PostIf it is in fact the Daylight running lights that you are looking to change, here are some intructions I put together for another forum. Make sure headlight switch is off or it will not work.
To change DRL state:
Left = DRL OFF
1) Headlight switch to OFF,
2) Select Left indicator while
3) Simultaneously holding the stalk hard back towards you to flash the lights while
4) Simultaneously cycling IGN on for a couple seconds - until you hear the DING.
DRLs are now OFF.
Right = DRL ON
2) Select Right indicator while
DRLs are now ON
I know sometimes people are a little confused about what the daytime driving lights are and don't understand that they can be set to be on (or off) whenever you start the car. My tsi is black so I prefer them to be on - it makes the car stand out better.
Found the info on 'how to do' in the manual, but my mistake was not turning the headlights from auto to off before I tried to activate them.
Thanks again!~Nic~
Deep Black Mark VI Comfortline 118 tsi - manual/sports pack, MDI
I dont get the Day Time Running Lights on the GTI. Help
Hey guys,
I finally picked up my GTI this morning. I have had the windows tinted today and been playing with all the gizmo's.
The thing which I am stumped on is the Day Time Running Lights.
The twisty thing on your right.
- Middle = Auto
- 1 turn to the right and it turns the day time running lights on
- another turn to the right turns the foglights on.
How do you make it so the daytime running lights are always on, and also have it so the headlights turn on automatically when needed?MK6 GTI 3 Door - Candy White - DSG - Sunroof - 18" Detroit - ACC - PA - RC - MDI - BT - RNS510.
Ok OK Ok, since you haven't stated, I am assuming you dont have Xenon,Originally posted by sharkablue View PostHey guys,
- Middle = Auto
So you have 4 options on the light knob, Off, Auto, Parkers, Low Beam
To activate the foglights - pull out half for front, and full for font and rear
Select Off or Auto, and Middle lights(in the high beam cluster) stay on, the cluster is fully illuminated similar to low beam, and these are the DRL
Select parkers, the same cluster of light, but will dim by 75%, a wee little globe
Select low beam , and the DRL will go off
The only way you can select the fog, is by pulling out the knob
See the manual in case the DRL's are off, its easy to activate them
Cheers, hope that was as simple as possible2011 VW GTI Canadian Spec - DSG, Luxury Package, Technology Package, 18' Detroit's with All Seasons, Rear Park Assist, Monster Mats, Tints, and Continental Snow/Ice Tyres on 16in Alloys
Originally posted by DermotTo be quite honest I would be going back to your salesperson/dealer and asking what a handover is all about? They should of explained this in detail.
I have to agree. I found out this kind of info on delivery...and was told that DRL's couldn't be turned off.tornado red GTI MkVI, 5dr, DSG, Sat Nav, RVC, MDI.
Red Honda Fireblade Red Cooper S (SOLD)
When I asked about them, the rep said that if I leave the headlight switch on Auto that the Day Time running lights will be on and if it gets dark the headlights will turn on.Originally posted by DermotTo be quite honest I would be going back to your salesperson/dealer and asking what a handover is all about? They should of explained this in detail.
I noticed after I parked it this evening that the day time running lights were not working.
I have followed the above instructions and it worked a treat.
Can the same thing be done on a Tiguan?MK6 GTI 3 Door - Candy White - DSG - Sunroof - 18" Detroit - ACC - PA - RC - MDI - BT - RNS510.
DRL's can be turned off, but it is a sequence that involves the ignition key and the indicator stalk. For ease of use, leave the cars light switch in Auto. When it gets dark, lights come on, when it gets bright, they will go off....
BTW, Tiguan does not have DRL's, but if it has the Comfort Pack (Ambience Pack) then it will have Auto Lights which is basically the same features as a Golf but minus the DRL's
Golf Mk6 118 TSI DSG |APR Stage I ECU Upgrade | HEX-USB+CAN
A good reason to use the DRL's (provided you leave your headlights on auto or remember to switch headlights on when it gets dark)
ACRS: Daytime Running Lights2018 Tiguan 110TSI Comfortline + DAP
Originally posted by night_flight View Postwhen I turn on my fog lights my headlights turn off is this how it is suppose to happen?Not true. Your headlights should remain on when your foglights are turned on. I've never seen a car that turns off its headlights when foglights are switched on - including my GTI.Originally posted by Idle View PostYes, that's why they exist — to cut through/under the fog where the headlights would just reflect back and blind you.2008 MkV Volkswagen Golf R32 DSG
You need to flick the headlight switch to ON before you pull it out for the fog lights to come on, then your headlights should remain on.Originally posted by night_flight View Postwhen I turn on my fog lights my headlights turn off is this how it is suppose to happen?MkVI Golf GTI | Candy White | DSG | Leather | Bi-xenon | Sunroof | Dynaudio | Park Assist | MDI | Tint | FINALLY RECEIVED!!
