Originally posted by maca
View Post
But now that you mention it cycling the comfort setting does re-activate DRLs. For those who don't know - Comfort setting are the optional 4 indicator flashes you get when you momentarily press the indicator part way. Great for when overtaking. If this comfort setting is OFF then the indicators only come on when fully selected. The reason I know that cycling comfort settings activates DRLs is that I generally have my DRLs set to off, but if I use VAGCOM to change the comfort flashes from the default 4 to anywhere in the acceptable range 1-5 DRL come back to life. Go figure.
But for me I find the easiest way select left indicator while simultaneously holding the stalk hard back towards you to flash the lights while cycling IGN on for a couple seconds - until you hear the DING. DRLs are active. Same as above with right indicator to reverse it. No need to start ENG.
