Is is possible to buy a non remote (dumb) key for current VWs? Not keen on leaving my car keys in the wheel well when I go surfing. The 2 provided remote keys will drown if i take them swimming. So I reckon I need a plain old metal key. is there such a beast?
MK6 Golf Key / Remote thread
the mk IV came with one
|Golf Mk VI 118TSI|Manual|Pearl Black|Sports Pack|Sunroof|F & R Parking Sensors|Park Assist|RVC|Alarm|RNS-510|VW Premium Bluetooth|MDI| http://www.hoodiaslimming.com.au - 100% Pure, 100% Organic
I have one of these when I paddle my kayak, and they are indeed solid units. If I forgot the combo, I reckon I'd be screwed, as the tumblers are a quality unit. Mine isn't this exact brand, but it's a full metal jobbie with a very solid lock. I clip it onto my towbar eyelets.
Last edited by Greg Roles; 26-11-2009, 08:36 PM.2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
Greg that Key Safe looks like it would be a workable solution. My preference would be for small waterproof key that i could carry with me. Is this actually possible or do all the modern keys need a chip in them for the immobiliser? Is it in fact a valet key I am after?Golf Mk6 118 TSI DSG |APR Stage I ECU Upgrade | HEX-USB+CAN
Non Genuine
You can even get non genuine ones and get them cut just get the cut code off your dealer if its only for what you want it for putting it in the water then why not get a cheap non gen oneOriginally posted by logger View PostIs is possible to buy a non remote (dumb) key for current VWs? Not keen on leaving my car keys in the wheel well when I go surfing. The 2 provided remote keys will drown if i take them swimming. So I reckon I need a plain old metal key. is there such a beast?
if you get a key with a transponder it prob wont work after getting it wet alot depends how well sealed it is not sure if you can get them for Immobilizer 4 yet but
Thanks will make some inquiries because essentially that is what I want.Originally posted by VWweirdo View PostYou can even get non genuine ones and get them cut just get the cut code off your dealer if its only for what you want it for putting it in the water then why not get a cheap non gen one
if you get a key with a transponder it prob wont work after getting it wet alot depends how well sealed it is not sure if you can get them for Immobilizer 4 yet butGolf Mk6 118 TSI DSG |APR Stage I ECU Upgrade | HEX-USB+CAN
If you want to hide your normal remote in the car and lock it with a "dead" key then it is very simple to just buy a blank plain key without an immobiliser chip. Lots of good locksmiths can do a computer controlled VW key cut, some will even have a VAG blank available. If not, blanks are readily available on line.Originally posted by logger View PostIs is possible to buy a non remote (dumb) key for current VWs? Not keen on leaving my car keys in the wheel well when I go surfing. The 2 provided remote keys will drown if i take them swimming. So I reckon I need a plain old metal key. is there such a beast?
If you really want a key that will operate your engine that his a whole new (and more expensive) ball game. The only place I've found that can supply an immobiliser chip that works in modern VAG vehicles is the VAG dealer, and you also have to get the ECU programmed to recognise the new key. The immobiliser chip is totally waterproof (but not the remotes).
Remember to wipe off the salt water before putting it in the lock, otherwise it will corrode the pins/wafers.2017 MY18 Golf R 7.5 Wolfsburg wagon (boring white) delivered 21 Sep 2017, 2008 Octavia vRS wagon 2.0 TFSI 6M (bright yellow), 2006 T5 Transporter van 2.5 TDI 6M (gone but not forgotten).
...and the blood when you poke it into your thigh wiping out. Perhaps you don't fall off as much as I did in my glory days...2014 Skoda Yeti TDI Outdoor 4x4 | Audi Q3 CFGC repower | Darkside tune and Race Cams | Darkside dump pDPF | Wagner Comp IC | Snow Water Meth | Bilstein B6 H&R springs | Rays Homura 2x7 18 x 8" 255 Potenza Sports | Golf R subframe | Superpro sways and bushings | 034 engine mounts | MK6 GTI brakes |
You have the APR flash as well, might be worth looking into adding the security option so that you have to enter a pin number to start the car. This way if someone breaks into the car (I assume you have no alarm) and finds the keys they won't be able to drive the car.Originally posted by logger View PostThanks will make some inquiries because essentially that is what I want.website: www.my-gti.com
Good idea. Considered it early on, but decided against it for two reasons;Originally posted by Maverick View PostYou have the APR flash as well, might be worth looking into adding the security option so that you have to enter a pin number to start the car. This way if someone breaks into the car (I assume you have no alarm) and finds the keys they won't be able to drive the car.
1) For me is is not worth the ~$400 cost
2) the lock/unlock process is too convoluted for my liking.Golf Mk6 118 TSI DSG |APR Stage I ECU Upgrade | HEX-USB+CAN
You don't have to use it every time and your insurance company won't pay out if you leave your keys in the car. Could be the best $400 you spent!Originally posted by logger View PostGood idea. Considered it early on, but decided against it for two reasons;
2) the lock/unlock process is too convoluted for my liking.website: www.my-gti.com
This is what I loved about my Mercedes key. The metal eyelet for your key ring popped out and became a regular old surf proof key. Lock the fancy electrical bit in the glove box and lock the door with the key and away you go. As I sold that I'm worried about how I'm going to go when I get the key with the Skoda. So, hope to hear of a solution soon!
MY10 Skoda Octavia RS Wagon TSI Candy White DSG Leather Sunroof MDI Bluetooth Tow Tint
MY11.5 Mk6 Golf GTI 5dr Candy White DSG Detroits MDI Bluetooth Bi-Xenons RVC Tint R-Tails - SOLD
MK5 R32 3dr Black DSG - Loved it
MY14 CLA45 AMG
Here's some info about Skoda keys :Originally posted by backdoc View PostI'm worried about how I'm going to go when I get the key with the Skoda. So, hope to hear of a solution soon!
