Originally posted by Kiark
View Post
118TSI - General Discussion
Yeah if you ask the VW service guys, they know the score. They know which cars have problems and which generally don't. Most of them will say get the diesel, it will go for 300,000 generally without any major issues. Even better, get the 6 spd manual. But the 6 spd DSG is still a pretty reliable transmission generally speaking
If you want the most reliable vw combination, it'd be a diesel like the 103TDI and a manual gearbox. If I were in the market to buy again, I'd stay away from the 118TSI just because of the horror stories. Great car if it works, but with the amount of people reporting issues, I'd stay safe and avoid it. Save a little extra for a GTI or get a 103TDI and an ECU tune.'09 mk5 Jetta 118TSI
'11 C7 A6 3.0TDI
'11 B8 A4 3.0TDI - RIP
Originally posted by Tobes_WIR35 View PostI am starting to look around for possibilities for my new car when my lease runs out next year. I was thinking of a Tiguan 4x4 diesel manual, until I found out they don't sell manuals anymore!
Yes manual is a safer option if you're going to hang onto it long term. That's why you'd buy a Mk7 90TSI manual. Otherwise you just need to get on the new car merry-go-round and upgrade every 3 years before the warranty runs out.
Originally posted by tigger73 View PostTobes the 4x4 Tiguan has the DQ500 "wet" 7 speed DSG which is the same gearbox that is used in the Audi TT-RS and Transporter. It's been designed for the high performance and heavy duty applications with a max torque of 550Nm. This is pretty much bullet-proof and completely different box to the DQ200 "dry" 7 speed which is used in the lower power Golf and Polos.
From my basic understanding, the DQ200 generates too much heat which it can't dissipate properly and ends up cooking itself.
This is made worse by how much the gearbox "rides the clutch" in slow speed traffic. If you're caught doing a lot of crawling the DSG will slip the clutch to keep everything nice and smooth, however this generates a lot of heat. With the gearbox running "dry" with only a small amount of oil there's not so much fluid to transfer the heat. To make things worse, the electronics are mounted right nearby and this ends up getting cooked along with the gearbox itself.
I don't think so but there's a lot more fluid which helps with heat transfer. The "dry" clutch design is trying to save on expensive DSG oil to try and reduce costs... but this then has had an impact on life of the unit.
Yes it's liquid gold!
Originally posted by tigger73 View PostFrom my basic understanding, the DQ200 generates too much heat which it can't dissipate properly and ends up cooking itself.
Originally posted by Rawcpoppa View PostShouldn't this be caught in testing? The damn thing has been in production since what? 2007? 2008? Ford uses a dry clutch DSG as well and I don't hear owners complaining of transmission control unit failures.
I had a Ford Focus dual clutch auto in America last year, the thing lost all power on the freeway and came to a clunky halt half way between Santa Barbara and Monterey. I left it for a bit, restarted the car, engine light on, limped it for about 100 miles to the rental desk at Monterey Airport waiting for it to die completely at any time... Not a pleasant experience.
