Just noticed the European release of the new transporter. Top of the range has a twin turbo 2l common rail diesel. It is claimed to have 132kW /400Nm and run a 7 speed DSG. Hmmmmm.
7 sp DSG 400Nm?
It will likely be the Audi S-Tronic 7 speeder, published torque up to 550nm.Originally posted by cme2c View PostJust noticed the European release of the new transporter. Top of the range has a twin turbo 2l common rail diesel. It is claimed to have 132kW /400Nm and run a 7 speed DSG. Hmmmmm.
Not the baby one seen in the cars.sigpic
I think that the Audi S-tronics box is too long to fit transversally. They would have to change engine/box arrangements to fit it.Originally posted by gerhard View PostIt will likely be the Audi S-Tronic 7 speeder, published torque up to 550nm.
Not the baby one seen in the cars.Performance Tunes from $850Wrecking RS OCTAVIA 2 Link
I read today something along the lines of "VW has had to beef up their DSG box to suit" http://www.carsales.com.au/reviews/2...neration-16785Originally posted by Transporter View PostI think that the Audi S-tronics box is too long to fit transversally. They would have to change engine/box arrangements to fit it.
So I looks as though there is plenty of potential in the 7 speeder with dry clutches.
Would that mean the dry 7 speeder will eventually replace the 6 speed oiler across the entire range where the donk is a high torque one?sigpic
They are using it in the S3 http://www.egmcartech.com/2008/09/30...d-twin-clutch/Originally posted by Transporter View PostI think that the Audi S-tronics box is too long to fit transversally. They would have to change engine/box arrangements to fit it.2009 118 TSI
1980 Bedford van
2015 Hyundai i30 SR
Errm, No .... S3 uses a 6speed DSG (S-Tronic) That article is incorrect. (it is also a year old) Have a look at the specs on Audi's websites ....Originally posted by cme2c View PostThey are using it in the S3 http://www.egmcartech.com/2008/09/30...d-twin-clutch/
7Spd DSG (as in Q5) is for a longitidunal engine not for transverse. T5/T6 & Amarok will get the 7Spd.
VAG does not have a 7spd DSG for the transverse engines rated above 250NM. 7Spd DSG for longitidunal engines only rated @ 550NM.
It is a totally different gearbox. It will not fit in a FWD car such as a Golf etc.Last edited by Sharkie; 25-09-2009, 10:41 AM.Current: 2023 MY23 T-Roc R Lapiz Blue + Beats Audio + Black pack 2018 MY19 Golf R manual Lapiz Blue + DAP) 2014 Amarok TSI Red (tuned over 200kw + lots of extras) 2013 Up! manual Red 2017 Polo GTI manual Black Previous VWs and some others ...
Which brings me back to my original point. What 7 speed DSG is VAG going to use in the transverse engined transporter and could it be grafted to the Golf etc?Originally posted by Sharkie View PostErrm, No .... S3 uses a 6speed DSG (S-Tronic) That article is incorrect. (it is also a year old) Have a look at the specs on Audi's websites ....
It is a totally different gearbox. It will not fit in a FWD car such as a Golf etc.2009 118 TSI
1980 Bedford van
2015 Hyundai i30 SR
Haha, which brings me back to my last post -Originally posted by cme2c View PostWhich brings me back to my original point. What 7 speed DSG is VAG going to use in the transverse engined transporter and could it be grafted to the Golf etc?
"I read today something along the lines of "VW has had to beef up their DSG box to suit" http://www.carsales.com.au/reviews/2...neration-16785
Would that mean the dry 7 speeder will eventually replace the 6 speed oiler across the entire range where the donk is a high torque one?"sigpic
That would be a good thing. OTOH, is the "beefing up" real or have they not changed anything except the spec sheet, crossing out 250Nm maximum and substituting 400? APR seems to have no problem putting 300+ Nm through the 7 speed dry clutch DSG with their 151kW 1.4 twincharger reprogram. This is relevant to me as a 118TSI DSG is off the boat and (slowly) heading in my direction. Also, the reduction in complexity and servicing costs with the dry clutches vs wet would annoy me if I had bought a 103TDI.Originally posted by gerhard View PostHaha, which brings me back to my last post -
Would that mean the dry 7 speeder will eventually replace the 6 speed oiler across the entire range where the donk is a high torque one?"2009 118 TSI
1980 Bedford van
2015 Hyundai i30 SR
You could be right there, VW quotes a spec which in the case of both the 6 and 7 speeders is way below the danger level.Originally posted by cme2c View PostThat would be a good thing. OTOH, is the "beefing up" real or have they not changed anything except the spec sheet, crossing out 250Nm maximum and substituting 400? APR seems to have no problem putting 300+ Nm through the 7 speed dry clutch DSG with their 151kW 1.4 twincharger reprogram. This is relevant to me as a 118TSI DSG is off the boat and (slowly) heading in my direction. Also, the reduction in complexity and servicing costs with the dry clutches vs wet would annoy me if I had bought a 103TDI.
The "beefing up" is probably only to the clutch spring strength, similar to what APMitchell has done on his turbo R32, now feeding 500+hp through the DSG (and way more than the 350nm specc'd limit).
The servicing cost of ~$400 for the 6 speed DSG every 60,000k is not excessive by any auto transmission service standards. But the lesser cost of the 7 speeder is better still.sigpic
Could it be that the 250Nm "limit" is not to do with stress on the gearbox per se, but instead, its ability to reliably change gears in a smooth and satisfactory fashion? So while it can cope with the extra Nm's without fear of damage, the average user may not be satisfied with the quality and smoothness of all the changes. Planned improvements to the software controlling the DSG may be able to alleviate this. Just a thought, based on limited observations with my tuned car.Golf Mk6 118 TSI DSG |APR Stage I ECU Upgrade | HEX-USB+CAN
Last 2 autos we had(2003 Peugeot and 2007 Honda) both had transmissions that were sealed for "life". Servicing costs zero. Of course, if it broke that would be expensive.Originally posted by gerhard View PostYou could be right there, VW quotes a spec which in the case of both the 6 and 7 speeders is way below the danger level.
The servicing cost of ~$400 for the 6 speed DSG every 60,000k is not excessive by any auto transmission service standards. But the lesser cost of the 7 speeder is better still.2009 118 TSI
1980 Bedford van
2015 Hyundai i30 SR
