2013 Golf Mk6 roof malfunction
  • 2013 Golf Mk6 roof malfunction
    Hi guys first post hopefully I can get some ideas about why the cabrio roof doesn’t open,
    1) roof un latches ok and mechanism spins and makes micro switch sends power briefly to pump only for a split second nothing happens no noise from the hydraulic pump.
    2) replaced roof module in boot still not working
    3) My Daughter said she heard a popping noise and what sounded like air coming out from top left side of roof
    4) opened roof manually to inspect couldn’t see anything untoward
    5) fluid level when roof is closed is well below minimum ( is there a low pressure sensor that could be holding it out?)
    6) fuses are all ok although there is no assignments of fuses so checked all of them all ok
    7) so currently using the small T handle to open and close roof
    so that’s it really any advice would be greatly appreciated thanks for reading
