Mk6 Golf wagon issues with LED bulbs.
  • Mk6 Golf wagon issues with LED bulbs.
    Weird question here.
    I have mk6 golf wagon. I have issues with intermittent warning for side bulb out? I installed canbus enabled w5w bulbs and they work fine. But every now and then when starting the car I get the bulb out warning. And it’s only ever the left side. Any ideas? I’ve swapped bulbs. Even a different brand no change. Same intermittent warning.
    Any ideas or solution?
    This is caused by the hot-diagnosis vs the cold-diagnosis function in the BCM; the BCM will pulse the light for a few milliseconds to test resistance; the resistance of a cold filament globe is very low vs LED even with a resistor, and the warning will clear once the BCM sees a load on the circuit once the LED is on.
      Mine is staying on. The error doesn’t disappear?
        Quality error free bulbs are the way to go or switch back to halogen bulbs
