I have a mk6 gti and and only recently I have heard this ticking/rubbing noise, seems to coming from underneath my valve cover, I have done my timing chain 30,000 kms ago and it currently has 140,000 on the clock, has anyone experienced this sound or issue and is it a easy cheap fix?
Noise/rubbing on idle
Can you post up a video of the noise? Or post the video to Youtube and link to the video?
Does it sound like its on one side of the engine perhaps? Im wondering if it could be the high pressure fuel pump (right hand side of the valve cover). Otherwise are you sure its not your accessory belt and/or tensioner on the left hand side of the engine?
Here’s a quick video of the noise, I don’t think you can hear it through the camera
4 February 2022 - YouTube
I cant really hear anything that sounds obviously wrong in the video. The direct injection TSI engines are quite noisy at idle so most of the noise I can hear is the injectors.Originally posted by BrokenMk6gti View PostHere’s a quick video of the noise, I don’t think you can hear it through the camera
If you feel something isn't right then it might be time to get your mechanic to look it over.
Does it still run ok?
