Forum only readable to users
The server is being hammered again by crawlers, we are seeing tens of thousands of "users" online. Rather than give up and take the whole thing offline, I've switched it over so users must be logged in to even read the forum. I've also removed the ads completely once you're logged in since they are now basically worthless and annoying.
It's not ideal, but it keeps things online for now until I work out a better approach.
2010 Golf Fuel gauge fault
  • 2010 Golf Fuel gauge fault
    Good Day ( Apologies to those seeing this thread again )
    I purchased a golf with blown CAVD motor then replaced it with a CTH motor. Before I noticed the fuel was on E. On road test I went to the servo and filled up with $10
    I checked for codes, then measuring blocks. The gauge resistance is said to be 510 ohms. I did not pull the pump unit out because When I unplugged the pump and relay, I was expecting an open circuit fault on the cluster module but the fault remained the same (resistance too high). The vehicle has one pump module/ gauge (or at least that's all I could see). I tried to do adaptation as per Wiki but the menus and options to define resistance etc were not popping up. The access code on wiki was denied by the module. Not sure what to do next.
    Code:
    Wednesday,22,July,2020,16:30:08:41695
    Chassis Type: 1K-VW36 (1K0)
    Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72 77
    VIN: WVWZZZ1KZAW187659   Mileage: 86100km-53500miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    03-ABS Brakes -- Status: OK 0000
    04-Steering Angle -- Status: OK 0000
    08-Auto HVAC -- Status: Malfunction 0010
    09-Cent. Elect. -- Status: Malfunction 0010
    15-Airbags -- Status: OK 0000
    16-Steering wheel -- Status: OK 0000
    17-Instruments -- Status: Malfunction 0010
    19-CAN Gateway -- Status: OK 0000
    25-Immobilizer -- Status: OK 0000
    42-Door Elect, Driver -- Status: OK 0000
    44-Steering Assist -- Status: OK 0000
    46-Central Conv. -- Status: OK 0000
    52-Door Elect, Pass. -- Status: OK 0000
    56-Radio -- Status: OK 0000
    62-Door, Rear Left -- Status: OK 0000
    72-Door, Rear Right -- Status: OK 0000
    77-Telephone -- Status: OK 0000
    Address 17: Instruments (J285)       Labels:| 5K0-920-xxx-17.clb-SRI1
       Part No SW: 5K0 920 870 D    HW: 5K0 920 870 D
       Component: KOMBI         H05 0206
       Serial number: 00000000000000
       Coding: 770B00
       Shop #: WSC 01357 011 00200
       ASAM Dataset: EV_Kombi_UDS_VDD_RM09 A04040
       ROD: EV_Kombi_UDS_VDD_RM09_004_VW32.rod
       VCID: 2E1000A071B59AF6A9-807A
    1 Fault Found:
    9453074 - Fuel Level Sensor 1
              B103E 1B [009] - Resistance Too High
              Confirmed - Tested Since Memory Clear
                 Freeze Frame:
                        Fault Status: 00000001
                        Fault Priority: 2
                        Fault Frequency: 1
                        Reset counter: 209
                        Mileage: 86108 km
                        Date: 2020.07.22
                        Time: 01:53:22
    Address 09: DTCs cleared
    Control Module Part Number: 5K0 920 870 D
      Component and/or Version: KOMBI         H05 0206
               Software Coding: 770B00
                Work Shop Code: WSC 01357
    Advanced Identification/FAZIT
         Identification: VDD-024
         Date: 14.10.09
         Manufacturer number: 1901
         Test stand number: 3405
    Flash Status
         Programming Attempts(application): 0/0/0/0/0/0/0/0/0/0
         Successful Attempts(application): 0/0/0/0/0/0/0/0/0/0
         Programming Status: 00000000
         Flash Date: 00.00.00
    Software
         BAP: 01.04.01
         OSEK-OS: 03.14.00
         HiSpd Net: 01.10.00
    Misc.
         Hardware number: 5K0 920 870 D
         Workshop System Name: J285
         End of Line Equipment Level: ------------------
         ASAM Dataset Revision: A04040
    Car Info
         Chassis Number: WVWZZZ1KZAW187659
    VCDS Info:
           Labels: 5K0-920-xxx-17.clb-SRI1
         Date: 14.10.09
    Flash Status
    Software
         BAP: 01.04.01
         OSEK-OS: 03.14.00
         HiSpd Net: 01.10.00
    Misc.
    Car Info
    VCDS Info:
    Address 17,5K0 920 870 D,channel IDE00493-Display correction of fuel gauge,adapted from,0.0 ,to,120.0 ,
    Address 17,5K0 920 870 D,channel IDE00493-Display correction of fuel gauge,adapted from,-8.0 ,to,510.0 ,
    Address 17,5K0 920 870 D, channel IDE00493-Display correction of fuel gauge, adapted from,-2.0 ,to,0.0 ,
    UDS Adaptation Channel (1B): IDE00493-Display correction of fuel gauge
    Stored value 0.0
