I'm currently changing the timing belt on the wifes Golf. I have a couple of questions which hopefully this forum can help me on.
1. The water pump I have has 8 vains (veins, not sure), but the pump that came out of the car has 7. They seem identical in every other way. Will this be a problem given it's just pumping water around?
2. I knocked the pin out of the fuel pump location and only noticed after I had the water pump out. I turned the notch back manually to the hole and put the pin back in but I'm wondering if this is going to be a huge problem now? The pin on the crank is still in and TDC. Would something of moved or unwound? Do I need to do something before reassembly?
Cheers in advance
Cheers in advance
