Hi all. My son's car, a 2007 GTI 2.0L Turbo has developed an oil leak. Purchased not that long ago, upon the first oil change it became obvious the previous person who changed the oil WAY over torqued the oil canister. I needed a 36MM socket to loosen it, and LOTS of oomph. It came loose, we changed the oil, and since then it has had an oil leak. I looked to see if it was the O ring around the canister, but its not - it appears to originate between the block and oil canister mount - the part the canister threads into. It being a Turbo car, there's a bunch of piping in the front of the engine, which is making this job substantially more difficult than I thought it was going to be. I drained the coolant, removed some of the piping, removed the oil cooler, removed the bolts that hold the oil canister, and its loose, but still won't come out. Wondering if anyone can direct me to any further details that I'm missing about doing this job. I have the new gaskets for the oil canister mount to block mating surface, and also for the oil cooler. With the engine in the car, its a bear to work on, but I'm not planning on removing the entire engine to replace 2 little seals. Grr. Any advice, help or input would be appreciated.
Marlen (way over in Canada).
