G-8VXWWTRHPN Engine oil - Confused - VWWatercooled Australia
  • Engine oil - Confused
    Hi guys,
    I have a 2005 Golf MkV 2.0 TDI manual, knowing that 507.00 oil is recommended. However I red somewhere also saying for better protection, 5w-40 oil (which is Not 507.00) can be used, i.e. Penrite Enviro+ 5w40 - 505.01. Can you tell which one will be more suitable for my car? Or it makes no different since there is no particulate filter....?
    504/507 only, in these.
    "Better protection" is just marketing fluff.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
      Originally posted by talktokeith View Post
      Hi guys,
      Be careful when selecting oil for your TDI engine. Don't even for second trust the oil companies when they say the 5W40 over 5W30 will better protect your engine. The viscosity of the oil has little to do with the wear protection, it's the oil additives that do the job. It's twice as valid in the PD TDIs.
      Performance Tunes from $850
      Wrecking RS OCTAVIA 2 Link
        Nope def the 507 oil only you need the long wear/life additives
        2017 Golf Alltrack 135tdi All options
          Thanks guys! So I simply stick with 507 and dont worry about viscosity.
            All 504/507 oils are 5W30 anyway.
            '01 Beetle 2.0
              Finally have my first oil and filter done, got a bottle of nulon euro 5w30 and it has vw 504/507 written.
              Somehow this is the FIRST time I feel the car running smoother after a "service" !
