Hello!
**UPDATE** Problem solved.
-I've added the fix to the problem below-
Currently in the throws of a Mk5 Golf GTI DSG (2005) engine swap with a 97,000km replacement after the old one popped a cylinder.
New engine in today. Wired it all up, watered, oiled, battery back in and turned the key.
Problem is:
Engine cranks, fires, runs for 2 seconds at a bumpy idle then chokes out.
I can also crank engine and put foot down on accelerator and hear it purr (lovely i might add) up to 4000rpm ish then with foot still on pedal, revs will fall then it will splutter off.
My thoughts on the issue but open to any expertise:
Any help what so ever would be greatly appreciated as i would love to get it onto the road asap.
Cheers guys
Problem solved!
The intake manifold was throwing an error and couldn't be reset on the vag com.
The new motor I put in the car came with an updated flapper motor for the intake after they replaced the faulty one. The new flapper motor also needs an ecu software update which my current ecu doesn't have.
So all I did was swap the flapper motors from the new one, to the old one from the blown motor. Started first crank!
Problem is:
- I've scanned the car with fully licensed VAG-COM but didn't get anything that popped out at me. Will scan again tomorrow and add it to this post.
- Battery is old and will not hold charge. To make it crank I've been hooking it up to another smaller charged battery. Could the faulty battery stop the ECU from being happy with it?
- The keys are not locking and unlocking the car with remotes. Have been opening door and alarm can go off as it wont unlock remotely. Could this be causing the immobiliser to kick in?
- Further on this, the immobiliser signal and warning are not appearing when starting the car so I don't think its that issue.
- Could the High Pressure Fuel Pump be faulty and not show a code?
Cheers guys
Problem solved!
