Genuine Front MK5 Wind Deflectors Installation Question
  • Genuine Front MK5 Wind Deflectors Installation Question
    Hi guys
    I purchased a pair of second hand Genuine Volkswagen MK5 4-dr front wind deflectors and have a question regarding installation. I'm unsure if the original seller bought these new, however he advised me that he installed them using double-sided tape, and stuck them on the outside.
    Now I've gone off and bought some 3M tape, and was looking at fitment this morning before I install them over the weekend; and noticed that they slot in perfectly into the window channels and if I were to stick them on the outer they won't from my perspective be a perfect fit.
    Deflectors are identical to the below, advise would be fantastic. Thanks!
    Here you go
    https://youtu.be/SgPbSX6KZK8
    Skoda Octavia Vrs 2008 TFSI Race Blue
    | CC Phase 2 tune | BSH PCV revamp | DRL's | HID | LED's | 35% Tints | Towbar |es1099 HU | Rev. Camera | R8 Coils | Brisk LSG Plugs | Adams slotted Fr Rotors | Torque arm insert | 3" Down Pipe | High flow cat |GFB DV+ | VM Shifter Bushes |
      As far as I can recall, the genuine ones stick to the outside.
      You'll need to clean the surface with alcohol, and use an adhesive primer.
      And no, they were never a perfect fit.
      '07 Transporter 1.9 TDI
      '01 Beetle 2.0
        Correct. Mine were fitted by the dealer before I took delivery.
        Numerous Mk1 Golf diesels
          Thanks guys - installed the deflectors yesterday, lets hope they hold up with the heat
