Hi guys,
Followed a good youtube video and DIY (can add links when home if anyone wants them) to install my RHF door lock actuator from an ebay seller for $83 shipped. (Cheers Umai Naa!!)
The lock works as intended, the only thing is that it seems like there's less resistance in the handles now when opening the door, both inside and out, and the external handle seems to 'float' a few mm away from the door skin when in operation.
I've done the install and reseated the handle about 4 or 5 times with no luck. For those that have done this, The cable with the black tab is sitting as far to the outside of the external handle as possible, and the torx screw that holds the lock cylinder is screwed tight with the handle held out and the cylinder pushed in when tightening.
Any other thoughts of things to check or retry?
