DSG oil change, time based as well?
  • DSG oil change, time based as well?
    Hi,
    We all know that the DSG needs to be serviced every 60,000. But does anyone know if it is timed based as well, and if so what age interval?
    The reason I ask is that I do less than 5,000 per year in my MK5 GTI. At this rate, I would only need a DSG service every 12 years, which obviously is crazy. I looked around online for an answer and found conflicting advice.
    Thanks,
    Jesse
    MKV GTI
    Every 4 years, according to VW.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
      as above, 4 years or 60,000km whichever comes first.
      if i waited til 60,000km, that would be 10 years for my golf
      but you will find lot of cars under 60,000km in the market have not had it done despite it is already 5 or 6 years old...
      MINI Cooper S Clubman - FWD
        Yep 4 years.
        Timing belt might be due 6 or 7 years on those.
        MK4 GTI - Sold
        MK5 Jetta Turbo - Sold
          Does anyone know if the time-based 4 years also applies to the 60,000 Haldex service?
          2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
          Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
            Yes, unless it's an MY10-onwards, then it's every 3 years regardless of distance.
            '01 Beetle 2.0
              i did mine at 6 years and 60,000...no dramas!
              Current - 2015 Tiguan 155 R-Line.
              Previous - Jetta MkV 147 Turbo, Viezu Raceday mapped, Carbonio CAI, Quad Exhaust System, R8 Coil pack, Whiteline Swaybar, GTi Steering wheel with paddles, Alloy pedals, RNS510 & Leather.
                Yes it does
