So the central locking has stopped working on my drivers side door only. I have a 2005 golf 1.9td. Appreciate any assistance on how I can fix this. Cheers!
Central locking on my passenger side front door on my gti had stopped working when I bought it, even pressing the lock and unlock button inside didn't lock or unlock the door, I replaced the door locking mechanism, I bought one for $60 or so on ebay and fitted it myself, this requires taking off the outer door skin, takes about an hour
Ours has same problem. Key works on drivers door but not remote. The key is mechanically connected to the lock as first turn does nothing and second turn of the key unlocks the door. May be broken wire. Seems they use ordinary automotive wire which if you bend it a few hundred or thousand times will harden and then break. Not a good design. Have already had broken wire in hatch door.
