I have found info on VWvortex forums that the GTI engine is replaced with the new 2009 version as from March 08 builds.
This engine has a number of changes to balance shafts, camshafts, and ECU.
It notably has a compression ratio of 9.5 versus the previous 10.5. Apparently it's a bit wider, and would make installing a larger turbo difficult if not impossible due to less firewall clearance.
Will make chipping/ECU reflash a different proposition again.
