Hi guys,
need some help here, crawled under the Mk5, 2005, 2.0 FSI petrol, BLX motor, and found coolant at base on the engine, and looking up at the back of the block, I can see coolant weeping out between head and block near cyl 4!! I was about to start replacing the timing belt, but it looks like the project has got a lot bigger. The previous owner had used green coolant which may have contributed to the gasket leak?
anyway which gasket sets would you recommend and ones I should avoid? Any online or local Sydney stores you'd recommend?
Thanks in advance
Andrew
Thanks in advance
Andrew
