Help - repeated failing tail / stop light bulb
  • Help - repeated failing tail / stop light bulb
    Hi Folks,
    Have an interesting (frustrating) problem with my Mk V GTI - in the past 9 months of ownership I've had to replace the right side (rear) brake light bulb 3 times - most recently last night.
    I am now suspecting that there is an issue here with the bulb assembly or wiring, or something odd going on.
    I've used a Narva brand bulb for the past 2 replacements (Stop/Tail & Indicator - Products - Narva - P21W) - are these suitable? Or is this the cause of my problems?
    I find it odd that the LHS has been fine, and that the inner park-light bulb on the RHS has been fine too.
    Has anyone else had similar issues? Is there something specific I should be looking for?
    Any assistance would be greatly appreciated as I'm sick of changing light bulbs (that said, I can do it in <10min now!)
    Cheers.
    Matt
    Current - 2007 Golf GTI, DSG, RCD510, K&N Panel Filter, BSH PCV revamp, Bluefin Stage 1 tune, 18" Omanyt's with RE003s.
    Previous - 2003 Renault Clio Sport 172 - Flame Red. -Gone-
    Check that it's making good contact with the terminals.
    If it's constantly arcing out, it'll blow.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
      Always seems to happen on golf 5 especially the early ones.
      DARKHORSE DEVELOPMENTS
      BLUETOOTH KITS, REVERSE CAMERAS, SATNAV, UPGRADES/MODIFICATIONS, DIAGNOSTICS. ​0420839266
      BRISBANE/GOLDCOAST/IPSWICH
      www.facebook.com/Darkhorsedevelopments www.darkhorsedevelopments.com
        Thanks... Indeed I saw another with the same light not working on my way home a few days ago.
        Any other suggestions on what to investigate?
        Replacement still working fine...
