Wipers & Washer Pump problem on GT GOLF mk5 (not working)
  • Wipers & Washer Pump problem on GT GOLF mk5 (not working)
    Hi guys, if you could point me in the wright direction.
    My rear wiper and washer pump (front & back) don't work.
    My front wipers work just fine.
    I have tested all my fuses and they all work. I pulled the washer pump out and tested on 12V independent and found the pump to be operational just fine (loud and noise as they normally operate) .
    Should I be looking at some sort of relay somewhere? My VCDS diagnostic doesn't show anything wit this subject matter at all.
    I have further isolated the two fuse seats at 41 and 42 that control windshield washer pump and cigaret lighter are inactive,... although the 20A fuses are in correct position and working (tested in another slot and multimeter) .
    Is there a reason why entire line in a row in Fuse box would be inactive?
    _____
    Update,
    I have bypassed the two fuses with direct wire connection of the battery positive to the two seats.
    Everything worked perfect. Obviously all the components work ( pump, motors etc), but the power is not getting to the second last row (fuse box) 41, 41, 42 ,43, 44, 45//
    Does anyone have a clue here how I should proceed. Does this sound like the wiring issue or possibly J519 Control Module.
    I hope someone reads this post
    Could be a bad stalk.
    Go into the Steering Wheel Electrics Module with VCDS, and see if it's reading the switch positions.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
      also check your bonnet switch is working correctly and make sure it has a good earth at the pump wiring..
      BRISBANE / GOLD COAST
        I have excluded the switch positions as they are operational in my isolated tests when I connect direct 12V at the 41, 42 positions at fuse box seats fro the two in questions. All operations behave as should once bypassed.
        I'm suspecting at the J519 module. Specifically cluster of wires connecting to the (I) fitting location.
          VDub, the bonnet switch is fine and working ok.
          How would I test the Earth on the pump wiring?
            with a multimeter from battery positive to pump earth...you should get battery voltage if earth good
              Hey thanks VDub, I'll give that a test.....
              I'm just concerned why the entire row of fuses from position 40 is inactive
                Hey VDUB
                I have done the test and the voltage on the pump is there.
                Its seems that I'm not getting any power to my 3c8937049AB (j519) control unit.
                Everything else works but the dual wash pump, rear wiper and cigaret lighter as on the same section of the power board.
                ie, it affects all the fuses in 41, 42, 43
                how do I tackle this now.
                Al
                  Pm me a Vin mate, and ill give you an idea where to be looking. If all fuses in a row aren't powering up then it definitely sounds like either a relay or supply fuse.
                  Give me the VIN, what exactly isn't working and where you do/don't have power & earth.
                  Volks Handy
                    Also, unplug the relevant connector from J519, and check for a bent terminal pin. Have seen a few of these in the past.
                    '01 Beetle 2.0
                      Hey guys, sorry to necro this a bit, but I'm having this exact same problem. I'm wondering if a resolution was ever found?
                      To state out exactly what I'm seeing:
                      Golf GTI Mkv 2006
                      Front washer jets don't work
                      Rear washer jets don't work
                      Rear windscreen wiper doesn't work
                      12v Cigarette lighter connection no voltage
                      Heated seats don't work
                      All of these failed at the same time.
                        Did you check over everything covered in this thread ?
                        MK4 GTI - Sold
                        MK5 Jetta Turbo - Sold
                          Well I'm trying to discover if a solution was ever found. Sounds like lots of tests were done to isolate a part, but nothing was done that actually "fixed" it.
                          I'm planning on poking about with a multi-meter on the weekend.
                            My Golf 5 is doing this also. I thought I'd just take it to my auto electrician but don't have time.
                              All run off the same relay if i remember correctly. Can probably bring it up on elsa to check tomorrow if i remember
                              Volks Handy
