Hi guys, so yesterday i just fit an RCD510 to my 2005 VW Golf MK5 1.6 FSI SE, I've read on the internet that i will be having a battery drain so now i'm pulling out the fuse, Do you have a fix for it apart from updating the can bus? I've read that you can jump the fuse one lead in the radio holder and another one in an empty fuse but i don't know which to use on my fuse box since the once i saw are alot different, any help or someone had the same problem ?
The other thing is that after i changed my RCD300 to an RCD510 everything worked fine but the airbag light came on the dash, i tried disconnecting the battery and nothing happened when i start it goes away then it turns back on after 2 seconds what do you think it is from? Thanks
