Hi,
Recently go a vag com scan done on my MK5 GTI that was misfiring under load and comes up with the following faults. Can anyone tell me what they are? Coils need replacing? Cheers Chris
ddress 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 Q HW: 8P0 907 115 B
Component: 2.0l R4/4V TFSI 0020
Revision: 5BH16--- Serial number: VWX7Z0GN3NR8SL
Coding: 040300431C070160
Shop #: WSC 00046 412 00000
VCID: 3467C888570DDABE4F5-8061
4 Faults Found:
000768 - Random/Multiple Cylinder Misfire Detected
P0300 - 001 - - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 93981 km
Time Indication: 0
Date: 2000.00.00
Time: 15:03:34
Freeze Frame:
RPM: 4069 /min
Load: 100.0 %
Speed: 106.0 km/h
Temperature: 87.0°C
Temperature: 35.0°C
Absolute Pres.: 950.0 mbar
Voltage: 14.097 V
000769 - Cylinder 1
P0301 - 001 - Misfire Detected - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 93981 km
Time Indication: 0
Date: 2000.00.00
Time: 15:03:34
Freeze Frame:
RPM: 4069 /min
Load: 100.0 %
Speed: 106.0 km/h
Temperature: 87.0°C
Temperature: 35.0°C
Voltage: 14.097 V
008801 - Boost Pressure Control Valve (N249)
P2261 - 008 - Mechanical Malfunction - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 94626 km
Time Indication: 0
Date: 2000.00.00
Time: 09:12:06
Freeze Frame:
RPM: 1887 /min
Load: 10.6 %
Speed: 50.0 km/h
Temperature: 84.0°C
Temperature: 21.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 14.224 V
004243 - Bank 1; Fuel Measuring System 2
P1093 - 008 - Malfunction - Intermittent
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 94650 km
Time Indication: 0
Date: 2000.00.00
Time: 16:29:28
Freeze Frame:
RPM: 2313 /min
Load: 11.4 %
Speed: 31.0 km/h
Temperature: 84.0°C
Temperature: 23.0°C
Absolute Pres.: 1010.0 mbar
Voltage: 14.224 V
Readiness: 0000 0000
4 Faults Found:
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 93981 km
Time Indication: 0
Date: 2000.00.00
Time: 15:03:34
Freeze Frame:
RPM: 4069 /min
Load: 100.0 %
Speed: 106.0 km/h
Temperature: 87.0°C
Temperature: 35.0°C
Voltage: 14.097 V
000769 - Cylinder 1
Freeze Frame:
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 93981 km
Time Indication: 0
Date: 2000.00.00
Time: 15:03:34
Freeze Frame:
RPM: 4069 /min
Load: 100.0 %
Speed: 106.0 km/h
Temperature: 87.0°C
Temperature: 35.0°C
Voltage: 14.097 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 94626 km
Time Indication: 0
Date: 2000.00.00
Time: 09:12:06
Freeze Frame:
RPM: 1887 /min
Load: 10.6 %
Speed: 50.0 km/h
Temperature: 84.0°C
Temperature: 21.0°C
Voltage: 14.224 V
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 94650 km
Time Indication: 0
Date: 2000.00.00
Time: 16:29:28
Freeze Frame:
RPM: 2313 /min
Load: 11.4 %
Speed: 31.0 km/h
Temperature: 84.0°C
Temperature: 23.0°C
Voltage: 14.224 V
