Hi All,
Just traced an oil leak on my Mum's Mk5 back to what appears to be the Oil Filter/Cooler housing. It's getting quite bad and is leaving a fair few drops even after only an hour sitting on a driveway. It looks like it's coming from where the housing meets the block.
If anyone knows of a DIY to replace these seals that would be greatly appreciated! It seems to be a pretty common problem with the 2.0L N/As and even the GTIs it seems (must use the same housing?)
Alternatively, a DIY on removing the intake manifold would also be great so I can at least access the area better.
Any extra advice is greatly appreciated (part no.s for the the seals etc
Cheers,
Max
Cheers,
Max
