Hi, my next service for my GTI is the major 105k service.
Obviously I will change the timing belt and other parts as per the book, what other parts do you recommend to change while they are doing the timing belt?
I need to order some parts for my BMW so may as well order the VW parts from ECS at the same time as shipping is expensive.
I was thinking of changing the following OEM parts:
Timing Belt - 06F 198 119 A ( Genuine VW Cambelt Kit (Toothed Belt Repair Kit) consisting of 1 x Toothed Belt, 1 x Tensioner Roller, 2 x Relay Rollers, 2 x Bolts & a Nut)
Waterpump 06F121011 (original has plastic impeller, is it better to go aftermarket with metal impeller?)
Fuel Pump Cam Follower 06D109309C
Spark plugs OEM #101905631B.
Air Filter 06F133843A
Cabin Filter 1K1-819-653A
Oil filter (have some OEMs at home)
I will also replace the Diverter Valve with a OEM Revision D. I believe the part number is 06H145710DKT
Is it worth also changing the Serpentine Belt Part #06F-260-849-L?
Can anyone suggest any other parts I should change at the same time or any other tips for the major timing belt service.
I will get most likely get Volks Care in Boronia to do the actual service.
FYI the following were replaced a couple of years ago when I had issues with the car:
06F129101L PCV Valve
06F133482E VW INTAKE FLAP ADJUSTER MOTOR
