Hi guys,
Need help with my GT TDi golf 2007 2L/
Read heaps good things on here in the past now I hope one of fellow members can help me.
Brief history.
Had a little front end accident, just a cosmetic panel damage and a broken fan AC condenser.
Started the car briefly for 10 sec and past that just won't turn. Fuel pump is working and all lines are feeding correctly.
But the engine just won't turn. Battery is ok. Have spare. All instruments on dash are ok and working.
I have identified Speed sensor may not be the issue but the dreaded code P1517, Short with Ground.
My scanner tells me "05399 Power Supply Relay for ECU (J271 or J363) Electrical Malfunction P1517Short With Ground Intermittent!"
"Power supply Relay for ECU (J271 or J363) electrical Malfunction message.
Tested both (1ko 951 253a) 2x modules on my other car and they seem to work fine.
Seems that ESC calls it Load Reduction Relay. Audi calls it Voltage Supply Relay and scan in VCDS calls it ECU Power Relay.
Apart from this scenario what else would you recommend to look at to fix the problem.
I did start the car for 10 sec and noticed that I have extra diesel in my Oil.
I emptied 3L and I'm still noticing more. Not sure if it could be the fuel Tandem Pump?
The car now just cranks and cuts off and that is after sparying diesel start spray.
Any help is greatly appreciated.
Brief history.
