vw golf gti steering control
    And one more thing...my mechanic says that my original steering module is faulty. .but when I connect it to ross tech it says Incorrectly coded
      After putting back my original steering control module...I have calibrated steering angle sensor but still no luck...now instead of steering limit stop incorrectly coded I get steering limit stop mechanical issue.
      My car seems a bit sluggish to start. Could it be that because of the battery being bad I get that steering problem still?
      This is my full code...
      Code:
      Saturday,12,April,2014,10:50:36:46862
      VCDS -- Windows Based VAG/VAS Emulator
      VCDS Version: 12.12.2.0
      Data version: 20140212
      VIN: WVWZZZ1KZ8U013581   License Plate: NO PLATE
      Mileage: 73660km-45770mi   Repair Order:
      Chassis Type: 1K (1K0)
      Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 55 56 62 72
      VIN: WVWZZZ1KZ8U013581   Mileage: 73660km/45770miles
      01-Engine -- Status: OK 0000
      03-ABS Brakes -- Status: OK 0000
      04-Steering Angle -- Status: OK 0000
      08-Auto HVAC -- Status: OK 0000
      09-Cent. Elect. -- Status: Malfunction 0010
      15-Airbags -- Status: OK 0000
      16-Steering wheel -- Status: OK 0000
      17-Instruments -- Status: OK 0000
      19-CAN Gateway -- Status: OK 0000
      25-Immobilizer -- Status: OK 0000
      42-Door Elect, Driver -- Status: OK 0000
      44-Steering Assist -- Status: Malfunction 0010
      46-Central Conv. -- Status: OK 0000
      47-Sound System -- Status: OK 0000
      52-Door Elect, Pass. -- Status: OK 0000
      55-Xenon Range -- Status: OK 0000
      56-Radio -- Status: OK 0000
      62-Door, Rear Left -- Status: OK 0000
      72-Door, Rear Right -- Status: OK 0000
      Address 01: Engine        Labels: 06F-907-115-AXX.lbl
         Part No SW: 1K0 907 115 Q    HW: 8P0 907 115 B
         Component: 2.0l R4/4V TFSI     0010
         Revision: 5BH16---    Serial number: VWX7Z0G83NH8FR
         Coding: 0403004318070160
         Shop #: WSC 00046 412 00000
         VCID: 3449F936578C61BE4FF-8061
      No fault code found.
      Readiness: 0000 0101
      Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
         Part No SW: 1K0 907 379 AC    HW: 1K0 907 379 AC
         Component: ESP FRONT MK60      0101
         Revision: 00H11001
         Coding: 0004738
         VCID: 73CB3A2A12022686965-8026
      Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
         Part No SW: 1K0 907 044 BS    HW: 1K0 907 044 BS
         Component: ClimatronicPQ35 120 1111
         Revision: 00120021    Serial number: 00000000000000
         Shop #: WSC 00000 000 00000
         VCID: 79D70802306E5CD6DC9-802C
      Address 09: Cent. Elect.        Labels: 3C0-937-049-30-H.lbl
         Part No SW: 3C0 937 049 AJ    HW: 3C0 937 049 AJ
         Component: Bordnetz-SG     H54 2202
         Revision: 00H54000    Serial number: 00000007643557
         Coding: E70F8E2700041500471400001400000000087F075C000100000000000000
         VCID: 71C73022681E1496649-8024
         Subsystem 1 - Part No: 1K2 955 119 E  Labels: 1KX-955-119.CLB
         Component: Wischer 021107 020  0501
         Coding: 00049109
         Shop #: WSC 00046
         Subsystem 2 - Part No: 1K0 955 559 AF  Labels: 1K0-955-559-AF.CLB
         Component: RLS     290807 046  0204
         Coding: 00208933
         Shop #: WSC 00046
      2 Faults Found:
      00156 - Control Circuit for Windshield Washer Pump
                  009 - Open or Short to Ground
                   Freeze Frame:
                          Fault Status: 01101001
                          Fault Priority: 3
                          Fault Frequency: 1
                          Reset counter: 81
                          Mileage: 73667 km
                          Time Indication: 0
                          Date: 2005.09.13
                          Time: 31:63:63
                   Freeze Frame:
                              ON
                          Voltage: 11.90 V
                              OFF
                              ON
                              OFF
                              OFF
                              OFF
      02398 - Control Circuit for Rear Windshield Washer Pump
                   Freeze Frame:
                          Fault Priority: 3
                          Fault Frequency: 1
                          Reset counter: 81
                          Mileage: 73667 km
                          Time Indication: 0
                          Date: 2005.09.13
                          Time: 31:63:63
                   Freeze Frame:
                              ON
                          Voltage: 11.90 V
                              OFF
                              ON
                              OFF
                              OFF
                              OFF
      Address 15: Airbags        Labels: 1K0-909-605.lbl
         Part No SW: 1K0 909 605 T    HW: 1K0 909 605 T
         Component: 1P AIRBAG VW8   020 2300
         Revision: 05020000    Serial number: 0038PD1EWCJ+
         Coding: 0012624
         VCID: 3D5FDC1264C6A0F6B01-8068
         Subsystem 1 - Serial number: 6332MSME23033335-
         Subsystem 2 - Serial number: 6342MSME27750D5CN
         Subsystem 3 - Serial number: 6352QSME374F3C11N
         Subsystem 4 - Serial number: 6362QSME3C0E2337M
      Address 16: Steering wheel        Labels: 1K0-953-549-MY8.lbl
         Part No SW: 1K0 953 549 BD    HW: 1K0 953 549 BD
         Component: J0527           636 0070
         Coding: 0003022
         VCID: 75CF04321C7638B6B81-8020
         Subsystem 1 - Part No: XXXXXXXXXXX
         Component: E0221           002 0010
      Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
         Part No SW: 1K6 920 874     HW: 1K6 920 874
         Component: KOMBIINSTRUMENT VDD 1216
         Revision: V0002000    Serial number: VWX7Z0G83NH8FR
         Coding: 0007103
         Shop #: WSC 40084 959 88113
         VCID: F0C1B526E3149D9EEB7-80A5
      Address 19: CAN Gateway        Labels: 1K0-907-530-V3.clb
         Part No SW: 1K0 907 530 L    HW: 1K0 907 951
         Component: J533__Gateway   H15 0180
         Revision:   H15       Serial number: 1400K0791108E0
         Coding: E9817F061002020003
         VCID: 3041F526A3945D9E2B7-8065
      Address 25: Immobilizer        Labels: 1K0-920-xxx-25.clb
         Component: IMMO            VDD 1216
      Address 42: Door Elect, Driver        Labels: 1K0-959-701-MIN3.lbl
         Part No SW: 1K0 959 701 M    HW: 1K0 959 701 M
         Component: Tuer-SG         006 1210
         Coding: 0000692
         VCID: 3851CD064BE485DE637-806D
      Address 44: Steering Assist        Labels: 1Kx-909-14x-44.clb
         Part No: 1K2 909 144 K
         Component: EPS_ZFLS Kl.5   D06 1701
      1 Fault Found:
      02546 - Steering Limit Stop
                  003 - Mechanical Failure
                   Freeze Frame:
                          Mileage: 3640 km
                          Temperature: 42.0°C
                          Voltage: 13.80 V
                          Voltage: 13.70 V
      Address 46: Central Conv.        Labels: 1K0-959-433-MAX.clb
         Part No SW: 1K0 959 433 BT    HW: 1K0 959 433 BT
         Component:    KSG PQ35 G2  020 0204
         Revision: 00020000    Serial number: 00000000000000
         Coding: 819002005103087F2D04840570085FC690FC00
         VCID: 832BEAEAC2A29606065-80D6
         Subsystem 1 - Part No: 1K0 951 605 C
         Component: LIN BACKUP HORN H03 1301
         Subsystem 2 - Part No: 1K0 951 178 A
         Component: Neigungssensor  003 0203
         Subsystem 3 - Part No: 1K0 951 178 A
         Component: Innenraumueberw.003 0203
      Address 47: Sound System        Labels: 3C0-035-456.lbl
         Part No: 1K6 035 456 A
         Component: 08K Audioverst.     0005
         Revision: 00003000    Serial number: 00000000143528
         VCID: 2A75E74E8548274EE53-807F
      Address 52: Door Elect, Pass.        Labels: 1K0-959-702-MIN3.lbl
         Part No SW: 1K0 959 702 M    HW: 1K0 959 702 M
         Coding: 0000692
         VCID: 3957C80270EE9CD69C9-806C
      End   ---------------------------------------------------------------------
