And one more thing...my mechanic says that my original steering module is faulty. .but when I connect it to ross tech it says Incorrectly coded
vw golf gti steering control
After putting back my original steering control module...I have calibrated steering angle sensor but still no luck...now instead of steering limit stop incorrectly coded I get steering limit stop mechanical issue.
My car seems a bit sluggish to start. Could it be that because of the battery being bad I get that steering problem still?
This is my full code...
Code:Saturday,12,April,2014,10:50:36:46862 VCDS -- Windows Based VAG/VAS Emulator VCDS Version: 12.12.2.0 Data version: 20140212 VIN: WVWZZZ1KZ8U013581 License Plate: NO PLATE Mileage: 73660km-45770mi Repair Order: -------------------------------------------------------------------------------- -------------------------------------------------------------------------------- Chassis Type: 1K (1K0) Scan: 01 03 08 09 15 16 17 19 25 42 44 46 47 52 55 56 62 72 VIN: WVWZZZ1KZ8U013581 Mileage: 73660km/45770miles 01-Engine -- Status: OK 0000 03-ABS Brakes -- Status: OK 0000 04-Steering Angle -- Status: OK 0000 08-Auto HVAC -- Status: OK 0000 09-Cent. Elect. -- Status: Malfunction 0010 15-Airbags -- Status: OK 0000 16-Steering wheel -- Status: OK 0000 17-Instruments -- Status: OK 0000 19-CAN Gateway -- Status: OK 0000 25-Immobilizer -- Status: OK 0000 42-Door Elect, Driver -- Status: OK 0000 44-Steering Assist -- Status: Malfunction 0010 46-Central Conv. -- Status: OK 0000 47-Sound System -- Status: OK 0000 52-Door Elect, Pass. -- Status: OK 0000 55-Xenon Range -- Status: OK 0000 56-Radio -- Status: OK 0000 62-Door, Rear Left -- Status: OK 0000 72-Door, Rear Right -- Status: OK 0000 ------------------------------------------------------------------------------- Address 01: Engine Labels: 06F-907-115-AXX.lbl Part No SW: 1K0 907 115 Q HW: 8P0 907 115 B Component: 2.0l R4/4V TFSI 0010 Revision: 5BH16--- Serial number: VWX7Z0G83NH8FR Coding: 0403004318070160 Shop #: WSC 00046 412 00000 VCID: 3449F936578C61BE4FF-8061 No fault code found. Readiness: 0000 0101 ------------------------------------------------------------------------------- Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl Part No SW: 1K0 907 379 AC HW: 1K0 907 379 AC Component: ESP FRONT MK60 0101 Revision: 00H11001 Coding: 0004738 Shop #: WSC 00046 412 00000 VCID: 73CB3A2A12022686965-8026 No fault code found. ------------------------------------------------------------------------------- Address 08: Auto HVAC Labels: 1K0-907-044.lbl Part No SW: 1K0 907 044 BS HW: 1K0 907 044 BS Component: ClimatronicPQ35 120 1111 Revision: 00120021 Serial number: 00000000000000 Shop #: WSC 00000 000 00000 VCID: 79D70802306E5CD6DC9-802C No fault code found. ------------------------------------------------------------------------------- Address 09: Cent. Elect. Labels: 3C0-937-049-30-H.lbl Part No SW: 3C0 937 049 AJ HW: 3C0 937 049 AJ Component: Bordnetz-SG H54 2202 Revision: 00H54000 Serial number: 00000007643557 Coding: E70F8E2700041500471400001400000000087F075C000100000000000000 Shop #: WSC 00046 412 00000 VCID: 71C73022681E1496649-8024 Subsystem 1 - Part No: 1K2 955 119 E Labels: 1KX-955-119.CLB Component: Wischer 021107 020 0501 Coding: 00049109 Shop #: WSC 00046 Subsystem 2 - Part No: 1K0 955 559 AF Labels: 1K0-955-559-AF.CLB Component: RLS 290807 046 0204 Coding: 00208933 Shop #: WSC 00046 2 Faults Found: 00156 - Control Circuit for Windshield Washer Pump 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 81 Mileage: 73667 km Time Indication: 0 Date: 2005.09.13 Time: 31:63:63 Freeze Frame: ON Voltage: 11.90 V OFF ON OFF OFF OFF 02398 - Control Circuit for Rear Windshield Washer Pump 009 - Open or Short to Ground Freeze Frame: Fault Status: 01101001 Fault Priority: 3 Fault Frequency: 1 Reset counter: 81 Mileage: 73667 km Time Indication: 0 Date: 2005.09.13 Time: 31:63:63 Freeze Frame: ON Voltage: 11.90 V OFF ON OFF OFF OFF ------------------------------------------------------------------------------- Address 15: Airbags Labels: 1K0-909-605.lbl Part No SW: 1K0 909 605 T HW: 1K0 909 605 T Component: 1P AIRBAG VW8 020 2300 Revision: 05020000 Serial number: 0038PD1EWCJ+ Coding: 0012624 Shop #: WSC 00046 412 00000 VCID: 3D5FDC1264C6A0F6B01-8068 Subsystem 1 - Serial number: 6332MSME23033335- Subsystem 2 - Serial number: 6342MSME27750D5CN Subsystem 3 - Serial number: 6352QSME374F3C11N Subsystem 4 - Serial number: 6362QSME3C0E2337M No fault code found. ------------------------------------------------------------------------------- Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl Part No SW: 1K0 953 549 BD HW: 1K0 953 549 BD Component: J0527 636 0070 Coding: 0003022 Shop #: WSC 00000 000 00000 VCID: 75CF04321C7638B6B81-8020 Subsystem 1 - Part No: XXXXXXXXXXX Component: E0221 002 0010 No fault code found. ------------------------------------------------------------------------------- Address 17: Instruments Labels: 1K0-920-xxx-17.lbl Part No SW: 1K6 920 874 HW: 1K6 920 874 Component: KOMBIINSTRUMENT VDD 1216 Revision: V0002000 Serial number: VWX7Z0G83NH8FR Coding: 0007103 Shop #: WSC 40084 959 88113 VCID: F0C1B526E3149D9EEB7-80A5 No fault code found. ------------------------------------------------------------------------------- Address 19: CAN Gateway Labels: 1K0-907-530-V3.clb Part No SW: 1K0 907 530 L HW: 1K0 907 951 Component: J533__Gateway H15 0180 Revision: H15 Serial number: 1400K0791108E0 Coding: E9817F061002020003 Shop #: WSC 00046 412 00000 VCID: 3041F526A3945D9E2B7-8065 No fault code found. ------------------------------------------------------------------------------- Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb Part No SW: 1K6 920 874 HW: 1K6 920 874 Component: IMMO VDD 1216 Revision: V0002000 Serial number: VWX7Z0G83NH8FR Shop #: WSC 00000 000 00000 VCID: F0C1B526E3149D9EEB7-80A5 No fault code found. ------------------------------------------------------------------------------- Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN3.lbl Part No SW: 1K0 959 701 M HW: 1K0 959 701 M Component: Tuer-SG 006 1210 Coding: 0000692 Shop #: WSC 00046 412 00000 VCID: 3851CD064BE485DE637-806D No fault code found. ------------------------------------------------------------------------------- Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb Part No: 1K2 909 144 K Component: EPS_ZFLS Kl.5 D06 1701 Shop #: WSC 00000 000 00000 VCID: 3449F936578C61BE4FF-8061 1 Fault Found: 02546 - Steering Limit Stop 003 - Mechanical Failure Freeze Frame: Mileage: 3640 km Temperature: 42.0°C Voltage: 13.80 V Voltage: 13.70 V ------------------------------------------------------------------------------- Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb Part No SW: 1K0 959 433 BT HW: 1K0 959 433 BT Component: KSG PQ35 G2 020 0204 Revision: 00020000 Serial number: 00000000000000 Coding: 819002005103087F2D04840570085FC690FC00 Shop #: WSC 00046 412 00000 VCID: 832BEAEAC2A29606065-80D6 Subsystem 1 - Part No: 1K0 951 605 C Component: LIN BACKUP HORN H03 1301 Subsystem 2 - Part No: 1K0 951 178 A Component: Neigungssensor 003 0203 Subsystem 3 - Part No: 1K0 951 178 A Component: Innenraumueberw.003 0203 No fault code found. ------------------------------------------------------------------------------- Address 47: Sound System Labels: 3C0-035-456.lbl Part No: 1K6 035 456 A Component: 08K Audioverst. 0005 Revision: 00003000 Serial number: 00000000143528 Shop #: WSC 00000 000 00000 VCID: 2A75E74E8548274EE53-807F No fault code found. ------------------------------------------------------------------------------- Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN3.lbl Part No SW: 1K0 959 702 M HW: 1K0 959 702 M Component: Tuer-SG 006 1210 Coding: 0000692 Shop #: WSC 00046 412 00000 VCID: 3957C80270EE9CD69C9-806C No fault code found. End ---------------------------------------------------------------------
