Coding dsg paddles
  • #16
    Coding dsg paddles
    Fair enough.
    I think the light dsg tune is adequate for me.
    It does still sway on the side of economy though.
    Platinum Grey mkV Jetta turbo, Viezu motorsport map, GT-CX 18", lowering to come
    • #17
      Originally posted by audi-tone View Post
      Fair enough.
      If I had my time again I'd put the DSG tune on first before adding paddles. Given that I changed both the steering wheel and airbag, the cost was almost as much as the DSG tune. However as the "D" mode shifting is sorted now, I don't use the paddles anywhere near as much as I used to.
      - Tigger73's 125TSI Build
      • #18
        Coding dsg paddles
        In what way does a proper dsg tune change the parameters? Higher revs before changes I'm assuming?
        • #20
          DSG computer uses both accelerator input and road speed to work out what gear to be in.
          The light DSG tune changes the data being sent from the engine's ECU to DSG mechatronics. So it can "trick" it to hold onto gears a bit longer.
          The DSG tune actually changes the programming so that D mode is no longer so economical and will actually change up straight away when you put the boot in.
          The other thing the DSG tune does is re-engages first gear. If you slow down it will drop back into first without having to come to a complete stop. So you can get going quickly without chugging in second.
          • #21
            Coding dsg paddles
            Ahh. I see.
            Interesting. Weirdly I kinda like D mode when I'm just putting round town.
            I can see the benefits though.
            • #22
              I picked up this old thread because I'm planning to do a DSG tune on my 2007 3.2L V6 Passat. Those who've done a DSG tune make lots of favourable comments, so it seems worthwhile. Harding Performance is the plan. I'm also thinking of installing a R36 whee so the coding info is really useful. My interest in the R36 wheel is more for the thicker rim - the paddles is a bonus. Wish there was a VW wheel with a smaller diameter that would fit!
              Never having had paddles before, I have a dumb question. If the gear shift is set to D, will the paddles work immediately if used or does the gear shift need to be flicked over to the left to the + and -? Thanks.
              2007 Passat B6 3.2 litre V6 4Motion | Granite Grey | standard 17" Solitude wheels | tow bar
              Mods: R36 steering wheel | HP DQ250 DSG tune | HPA Haldex performance controller | Koni sports yellow shocks | Eibach springs | H&R sway bars | Whiteline ALK | Kufatec E-MFA add on | Garage door button | Warning triangle retrofit | Bridgestone Potenza Adrenalin RE003s
              • #23
                If memory serves me correct, it will automatically activate in 'D' - without the need to move the lever into the 'triptronic' state.
                • #24
                  As soon as you hit the paddle it will change gears. If you're in "D" or "S" it will revert to that mode after 20 seconds or so.
                  • #25
                    Brilliant. Thank you.
