I live in Brisbane, where can I buy the above?
Rear Struts for Jetta mkV....where to buy???
This topic is closed.
Current - 2015 Tiguan 155 R-Line.
Previous - Jetta MkV 147 Turbo, Viezu Raceday mapped, Carbonio CAI, Quad Exhaust System, R8 Coil pack, Whiteline Swaybar, GTi Steering wheel with paddles, Alloy pedals, RNS510 & Leather.Tags: None
They aren't struts, just normal config shocks (struts would have the spring integral to the damper assembly). They'd take a bad Mechanic about 1 hour to change (3 bolts per side)
It's the same part as a MkV Golf or a 1Z Octavia.
If you intend to keep the car for a while then buy Koni Yellows. Try Fulcrum Suspension.
If you just want something to tide you over then Bilstein 300 or Sachs OEM replacement.
Why aren't you doing the front as well? Usually the front gets tired way before the rear.carandimage The place where Off-Topic is On-Topic
